Stronger Battery terminal clamp suggestions
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ceddingermtb, Feb 17, 2018.
  1. Feb 17, 2018 at 8:50 AM
    Ceddingermtb
    Ceddingermtb [OP] Well-Known Member
    Caleb
    Lake Arrowhead CA
    05 trd off-road dscsb
    Anyone know of any battery terminal clamps that are really strong? Every time I go off-roading my positive terminal clamp snaps right off, my battery is completely secured by 2 holders so that’s not the issue. Let me know!
  2. Feb 17, 2018 at 8:57 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Wut?
    That’s the first time I’ve ever heard of this. You have pics of your setup?
  3. Feb 17, 2018 at 9:05 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Military terminals
  4. Feb 17, 2018 at 9:05 AM
    anthony250f
    Anthony
    San Diego, CA
    Sounds like the cables are too short
    Kiloyard and Ceddingermtb[OP] like this.
  5. Feb 17, 2018 at 9:13 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    We've tested these things inside out, dropped them from hundreds of feet and we've never seen a hatch just blow
  6. Feb 17, 2018 at 11:43 AM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
  7. Feb 18, 2018 at 4:01 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Pictures We gotta see this !!
    Cable to long hanging down catches on something ??
    Short cable with a broken engine mount .
    cable secured with not enough slack between battery and starter
  8. Feb 18, 2018 at 5:35 PM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    Did you try a new OEM terminal? There is a guy on eBay that sells them for about $12 shipped. If you had some corrosion on them, time to replace - use NAPA cleaner and sealer as well
  9. Feb 20, 2018 at 7:34 AM
    Ceddingermtb
    Caleb
    Lake Arrowhead CA
    I’ll throw in some pics later
  10. Feb 20, 2018 at 11:30 AM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    I'd try and extend the wiring or check your battery mounts. Mine doesn't have a large amount of slack but it isn't close to pulling the terminal off.
    Oh and as a side note, I was up in Lake Arrowhead over the weekend, its basically the 1st gen capital other than San Clemente. Those things are everywhere.
    Ceddingermtb[OP] likes this.
  11. Feb 22, 2018 at 5:52 PM
    Ceddingermtb
    Caleb
    Lake Arrowhead CA
    Just noticed, I forgot to put pics in here, it’ll happen someday
  12. Feb 22, 2018 at 5:53 PM
    Ceddingermtb
    Caleb
    Lake Arrowhead CA
    Pretty sure I haven’t experienced one day where I don’t see another 1st gen up here
  13. Feb 23, 2018 at 12:17 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Found your problem ?
    Just to shy to share ??
  14. Feb 23, 2018 at 5:12 AM
    Indy
    Indy Master of all I survey.
    If you're breaking battery terminal clamps, you don't need better terminal clamps.
  15. Nov 21, 2018 at 10:52 AM
    Arctic Taco
    Arctic Taco Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    Brass ones from O’Reilly’s?
  16. Nov 21, 2018 at 10:57 AM
    will e
    will e Well-Known Member
    World Wide
    04 pre-runner
    Dominic Toretto Tuned with Extra Blinker Fluid
    sounds like a short cable
  17. Nov 22, 2018 at 1:43 PM
    beez
    beez Well-Known Member
    Nate
    04 single cab PreRunner
  18. Nov 24, 2018 at 4:26 PM
    Ceddingermtb
    Caleb
    Lake Arrowhead CA
    Hey! Sorry for not replying ended up getting in a rollover accident, and the truck was totaled :(
