Stronger Front Diff?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jspadaro, May 19, 2011.
  1. May 19, 2011 at 7:21 AM
    jspadaro
    jspadaro [OP] Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Aside from a SAS, is there a way to make the front diff stronger?
    I'm just curious, in case mine were to crap out after I'm out of warranty.
  2. May 19, 2011 at 7:23 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    I vote for Toyota to make a driver's side needle roller bearing in the front diff that lasts.
  3. May 19, 2011 at 7:28 AM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    I'm specifically referring to the clunky noise that is related to the needle bearings as indicated above, which is NOT pretty strong, it's pretty crappy!
  4. May 19, 2011 at 7:43 AM
    05Moose
    Jim
    I know, but I also wanted to watch the thread to see if there are any alternatives out there (aside from SAS). We're up to 2 or 3 dozen people with the bad bearing problems.
  5. May 19, 2011 at 7:44 AM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Well yeah, agreed, that's why I started the thread. :D
    I guess a front diff isn't something a company is going to just machine and sell though... :(
  6. May 19, 2011 at 8:11 AM
    Wicked 2007
    Wicked 2007 Well-Known Member
    Bay Area, CA
    2007 Tacoma AT DC SB 4x4
    2007 Tacoma Double Cab SB 4WD - Auto -TRD Off Road - Icon Billet UCA - 8" ORI Front Struts - Bilstein 5100 11" RCD Shock - AllPro Expo Springs - Demello Sliders - Tom Woods 1 Piece Driveshaft - 16x8 Mojave Teflon Rims - Locker Mod - Locker Guard - 35" MT MTZ's - ARB Bumper - Warn 8000 winch w/synthetic line - All-Pro Front Skid/Transmission Skid/Rear Armor - ARB Front Locker - Nitro 4.56 gears - Marlin 4.7 crawl box - Twin Stick FJ t-case - ATO high clearance rear bumper
    I have aftermarket gears and an ARB - I wheel my truck a lot and use the front locker when I need - never had any issues with 42K on her...
  7. May 19, 2011 at 12:56 PM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    If the bearing is your only problem why not just replace that instead of the whole differential? You can swap in any differential you want but it's going to cost you more money than a bearing. You can swap one in from a newer Tundra and have some new axles machined.
  8. May 19, 2011 at 3:11 PM
    BenWA
    BenWA Well-Known Member
    Seattle @ 0.9 Mach
    '06 Double Cab TRD Off Road 4X4
    Have you actually been keeping any kind of record? I was under the impression that it was well over a hundred people scattered around the various forums who have complained of the problem but I could be way overexaggerating.
  9. May 19, 2011 at 4:47 PM
    05Moose
    Jim
    I started keeping track and then it got too distracting. The earliest failure of the bearing was at 11K miles (stock tacoma). The next earliest was 19K miles. Then several in the 28K-50K mile range. They're popping up again around 100K miles as people upgrade shocks only to find that they have bad bearings too. That number is closer to those that truly confirmed the front diff bearing as the problem (rather than just generally complaining about a vibration after lifting).
  10. May 19, 2011 at 5:07 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    these front diff threads are brutal. i feel for you guys that have issues.
    on a whim, i grabbed my front axles and jiggled them. my driver's side is pretty tight. the tiniest of movement. my passenger side is more loose, but still tight. i've lifted my truck a mere 2" in front. i am at almost 60k miles. i wheel hard during hunting trips.
    i had a leak at the driver's seal, and my dealership fixed it under warranty. it got me thinking; if you can get to the seal, getting to the bearing is just another layer of hell away, right?
    why do dealerships change out entire front diffs, when they can simply replace $60 bucks in parts?
  11. May 19, 2011 at 5:18 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Overland Build
    Millions
    Toyota needs to take some responsibility and issue a TSB with an updated reliable part.
    EDIT: According to this it's a ~$45.00 part. But the labor to get the part in there is the killer.
