Stronger springs than 4 leaf TSB package?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by news8000, Nov 1, 2008.
  1. Nov 1, 2008 at 2:07 PM
    news8000
    news8000 [OP] Active Member
    Southeast Manitoba, Canada
    06 Tacoma 4X4 Access Cab Stock
    ON STOCK UNIT: Rear Leaf TSB, Leer Cap w/ Windoors, Michelin LTX M/S on ION 133s, K&N Filter, Cruise, Python Command Start/Alarm, Toyota Class 5 Hitch, Metra IPod Adapter
    2006 Access cab stock model. I have the rear leaf/bilstein shocks (x4) TSB upgrade and would like to increase the load capacity somewhat more. I load up almost daily with carpentry tools/materials and given the rough rural roads it still ocassionally bottoms out. I'd rather have a stiffer ride and not prematurely sag out the springs given this truck will hopefully last me a good long time.
    Any suggestions or concerns about this out there?
    Thanks!
  2. Nov 1, 2008 at 2:09 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    get an aal for the rear, or a set of helper springs. either one should help with your load capacity and not sag the springs.
  3. Nov 1, 2008 at 2:12 PM
    news8000
    "get an aal for the rear"
    :confused: What' an aal??
  4. Nov 1, 2008 at 2:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    aal=add a leaf.......basically another leaf that you add to your leaf pack to make it stronger, and it will also left the rear just a bit.
  5. Nov 1, 2008 at 2:24 PM
    Brunes
    Brunes abides.
    Rotorhead
    Don't forget that the load limit is not based solely on the suspension. You need to consider transmisison capabilities, braking, and axel and frame weight bearing at a minimum...and I'm sure there are things I've missed..
  6. Nov 1, 2008 at 2:35 PM
    petersharp
    petersharp Well-Known Member
    Do you need to ask?! It's up there ^
    Louisville, CO
    Ex DC LB Sport owner.
    I went to a car mechanic one time and asked how much they would charge to put on a helper spring, and they refused to do the work. They said it affects so many other parts of the car it's not worth doing it, better to buy a bigger truck.
    If you want to stick with a Taco, how about buying a trailer? Then you can leave it loaded with all the stuff. In AZ there are masses of contractor's trailers for sale - I'm sure this is the case in most parts. All the alternative (dare I mention) is to ditch the Taco and buy a bigger truck.
  7. Nov 1, 2008 at 3:01 PM
    news8000
    I guess it's time to save up for a contractors trailer; lockable covered trailer to keep my tools etc. in and be safe to leave on work site as necessary. I have a small open homemade trailer but between rain and snow I have to empty daily of vulnerable tools. I have just ordered a raised profile Leer cap with 2 side windoors and a rack - that'll at least beat the hell out of the snapon tonneau I fought with over the last year every time it rained or snowed - and it gets absolutely horrible to close when the temp drops in our Manitoba winter. Can be -30f in the morning and the damn thing shrinks... :mad::mad:
    THANKS again for info as I was uncertain about extra load handling issues and advisability of pushing GVW too far. And that V6 has tons of trailer pulling power :D.
    This forum rocks!
  8. Nov 1, 2008 at 3:24 PM
    petersharp
    Louisville, CO
    I'm sure that the airbag coil helper system that I looked at was around $1000 to buy (instal was extra). I just looked at the local Craigslist and there are used 10' x 6' enclosed trailers starting at $1200. If you buy one of those, it'll still be worth something in a few years. A used suspension system won't (and it may even put a prospective buyer off buying your truck, if he knows it's been abused).
    And it'll give you some shelter out of the elements when you're trying to ogranize your tools/materials. It's a no-brainer!
