Strongest leaf spring to prevent axle wrap the best
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iamme776, Jul 7, 2014.
  1. Jul 7, 2014 at 2:35 AM
    iamme776
    iamme776 [OP] Member
    2014 TRD off road
    As the title states.....ive read alot about the springs people are choosing..Dakars, deaver, alcan, allpro... but havent seen anything where anyone speaks of which ones wrap the least.
    Im not worried about ride quality, it is a truck. but in anyones opinion, which are the stiffest brand that i could get that will put this axle wrap deal behind me already. The dealer said they would replace my springs, but im just gonna go aftermarket heavy duty, so i dont end up with the same issue after they swap stocks... they agreed to change them based on my constant nagging
  2. Jul 7, 2014 at 2:52 AM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Any aftermarket spring will be stiffer and help prevent axle wrap. I have never noticed it with my Dakars but then I never noticed it with the stock leaf pack either.
  3. Jul 7, 2014 at 3:34 AM
    iamme776
    2014 TRD off road
    well, ive got this annoying bumping feeling when i let on and off the throttle at highway speeds. it feels like its unloading and loading.... very annoying. i threw two sets of leaf spring helpers on, and it eliminated it 95%. id rather not bandaid it, but just get some nice stiff springs. i appreciate your comment, and im aware that aftermarket springs will stiffen things up, thats a given...... My question is which ones, by peoples experience, are the stiffest to their opinion. i know there are some people who have tried multiple brands or ride with people who have a variety of springs. Those answers would be greatly appreciated.
  4. Jul 7, 2014 at 3:54 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Get some traction bars!!
  5. Jul 7, 2014 at 3:57 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Get the 4 leaf packs from the dealer for free then sell those to me when you go with an aftermarket set.
  6. Jul 7, 2014 at 4:01 AM
    JJ48Nascar
    JJ48Nascar Member
    Josh
    08 Tacoma Prerunner V6 4.0L
    17 inch rims with Nitto Grappler tires. No lift kit
    There is acutally a TSB for the axle wrap or thud/clunk noise. The TSB calls for replacement of the drive shaft to an upgraded drive shaft. I took my Taco into the dealership for the thud/clunk noise in the rear or axle wrap as it is so called. They ended up replacing my entire drive shaft and I no longer experience any thud when letting of the brake and accelerating. I have wanted to replace my rear leaf springs or add a leaf spring helper, but it looks like replacement of the drive shaft has fixed it. Hope this helps.
    Here is a link to the list of TSB from another TW member:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/7107-tsb-list-2005-toyota-tacoma.html
    Here is a link to the TSB:
    T-SB-0250-12 DEC 12 - Drivetrain - 2WD Rear Propeller Shaft Clunk/Thunk Noise
  7. Jul 7, 2014 at 4:05 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Hey Jimmy, what's up?
  8. Jul 7, 2014 at 5:10 AM
    iamme776
    2014 TRD off road
    I thought about that...what traction bars are some using. I know ladder bars are better for wrap.
    And as for the TSB... i have a 2014 4wd trd... the TSB only goes to 2012 2wd
    Also... i appreciate all of the comments, really quick and helpful...
    But my question is about the stiffness of the said aftermarket springs. i heard of people talking about some flexing and whatnot... im looking to get some info on the stiffest ones in peoples opinion that would resist the wrapping issues the stocks have. The only thing close i hear are the dakars ride stiff.... so again, in anyones opinion. which would be the stiffest out of the bunch to resist the wrap. Thank you.
  9. Jul 7, 2014 at 5:25 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    The stiffest are probably the AllPro expedition. I had a set of AllPro Standard and Deaver and didn't had any problem with axel wrap.
  10. Jul 7, 2014 at 6:58 AM
    iamme776
    2014 TRD off road
    thank you... visually they looked the stiffest.. but everyone seems to go nuts for those dakars.... im torn between both.
  11. Jul 7, 2014 at 7:17 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    If you're stuck between Dakars and expos, like I was, look at the uses for your truck. They both are GREAT for towing, but if you will be hitting the trails and flexing more than towing, go with the Expos. If not, Dakars.
  12. Jul 7, 2014 at 8:03 AM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Are you planning on lifting the front as well? Truck will look mighty strange if you throw either of those on without lifting the front as well. Dakars will lift the rear about 2.5".
  13. Jul 7, 2014 at 4:03 PM
    iamme776
    2014 TRD off road
    Im most worried about preventing the twisting of the leafs. I put a gopro under my truck and i can see the pinion going dramatically up or down when on and off the gas. After installing two sets of leaf spring helpers on both the front and back of the spring... the clunking or bumping feeling is 95% gone.....
    So it sounds like the Dakars are the stiffest of the group. Im not doing any rock crawling, and dont mind a stiff ride on the trail...
  14. Jul 7, 2014 at 4:12 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    seriously... unless you have 500lbs constantly in the bed of your truck... dont go with the dakars.... buddies DCSB rides so stiff with the dakars... stiffer than my old 1 ton chevy... and the chevy was bone jarring.
  15. Jul 7, 2014 at 4:19 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    My dakars ride great but I have a full size spare, bestop, bedrack, and RTT over the bed.
  16. Jul 7, 2014 at 4:40 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    I'd Recommend the Dakar's. I love them
  17. Jul 7, 2014 at 6:13 PM
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    I love Dakars too, especially when I'm hauling a bulging bed load of mulch and no flex! :D
  18. Jul 7, 2014 at 7:25 PM
    bjboucher
    Brad
    San Antonio, Texas
    Ops still hasn't said if he was wanting to lift his truck though. If not, then neither set will work. He'll need some Wheelers HD packs or something that does not provide much lift.
  19. Jul 8, 2014 at 10:02 PM
    iamme776
    2014 TRD off road
    sounds like the dakars are mighty stiff.... im fine with the stiff ride. these double leaf helpers i put on have made it "bone jarring" stiff as it is. i'll go with them and hope for the best!
  20. Jul 8, 2014 at 10:07 PM
    iamme776
    2014 TRD off road
    I dont mind a little raise in the back. the double set of helpers raised the dang thing by almost two inches already and its a little higher in the back. that will only level things out when i haul or tow.
    If it ends up looking that stupid, i'll level it up front. no biggie. just time and a few more bucks.
