Strongest leaf spring to prevent axle wrap the best
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iamme776, Jul 7, 2014.
  1. Jul 9, 2014 at 4:31 AM
    Skunkman
    Skunkman Well-Known Member
    Syracuse - Tug Hill
    2007 Tacoma Access Cab ,
    I am running the Expo's on one of our Tacoma's and like them for our application. That being said, with 1000 pounds roughly on the truck, I still have 3 + inches of lift in the back. I wouldn't want to run them unloaded. Did you end up with Hellwig helpers and got the 2 " of lift ?
  2. Jul 9, 2014 at 5:40 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    If you don't want to lift too much i will say go with deaver. On your double cab it will produce probably 1 in. of lift maybe 1.5 in. I've tried different leafpack and about ride quality and plushness nothing compare to deaver standard J66 pack. But it will reduce a bit your load capacity so you will have to install something like timbren bumpstop.
  3. Jul 9, 2014 at 8:22 AM
    Rosscopeeko
    Rosscopeeko Well-Known Member
    BC
    08 DC LB 4x4 sport
    Wheelers hd springs. I just ordered some and I'm waiting to get them installed. They are supposed to raise the rear 2", but add a lot of carrying capacity.
