Struggle to start and she lack power
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sexyshadynasty, Oct 2, 2020.
  1. Oct 2, 2020 at 9:56 PM
    Sexyshadynasty
    Sexyshadynasty [OP] New Member
    Shad
    2012 Toyota Tacoma Baja
    Hey Guys!
    Ive got a long one but hoping I can get some guidance on this. For the last few months my Taco has been doing this weird thing where every 8-10 starts the truck will immediately turn off. I would start the truck back up and it would turn on and run just fine. Took it into a mechanic and he recommended and the recommended a fuel injection cleaning and air filter cleaning. Ran great for a week and the same thing happened. I took it back in and they said it might be the Mass Airflow Sensor so we replaced that and then a few days later the same thing started happening again.
    Then out of the blue it stopped happening! The truck was turning on and off as normal for almost a month. I was ecstatic... until last week when it started up again and this time much worse. Now every time I start the truck it turns off immediately and I have to give it gas to start the second time. And to make matters worse it almost feels like the truck has no power. I try to hit the gas to get up to 45+ mph and there’s just nothing. I equate it almost to the truck having asthma and is just out of breath when I work it too hard. Every so often the battery light will blink as well.
    I’m trying out a new mechanic on Monday cause I got sick of my last mechanic, so I’m posting this in the hope that someone has had a similar issue and they can point me in the right direction for my new mechanic.
    Thanks you ahead of time!
  2. Oct 2, 2020 at 10:01 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Any engine codes?
    clogged catalytic converters?
    ryfox0276 likes this.
  3. Oct 2, 2020 at 10:19 PM
    Bishop84
    Bishop84 Well-Known Member
    Wattapunk and Sexyshadynasty[OP] like this.
  4. Oct 2, 2020 at 11:28 PM
    Sexyshadynasty
    Shad
  5. Oct 2, 2020 at 11:52 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    I think he's taking it to another mechanic instead of playing a who done it guessing game with his truck with online arm chair quarterbacks, maybe you'd be better off to stick with the Agatha Christie mystery novels and let a professional diagnose the vehicle
  6. Oct 2, 2020 at 11:55 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    year ..... model....... miles
    used / new
    any OBD codes ????
  7. Oct 3, 2020 at 3:32 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    just for fun test the cranking voltage of your battery
  8. Oct 3, 2020 at 4:33 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Agree with this...Likely failing fuel pump. I would also recommend new spark plugs if they have never been replaced.
  9. Oct 3, 2020 at 4:45 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Im no mechanic but it does sound like a fuel pump. But also I noticed you have a 2012 does the secondary air pump have anything to do with the way its acting?
    BassAckwards likes this.
  10. Oct 3, 2020 at 4:56 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    The fuel pump has 2 windings? I thought the speed of the pump was controlled by a resistor, switched in and out of the pump circuit by the ECU.
  11. Oct 3, 2020 at 8:14 AM
    Sharpish
    Brian
    Back in your box Bill.
    b_r_o and BassAckwards like this.
  12. Oct 3, 2020 at 8:55 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Avoid mechanics who “think” it’s something. Find a mechanic who waits until he knows what rhe problem is before he fires the parts canon.
  13. Oct 3, 2020 at 9:00 AM
    Bishop84
    You're right, not two windings, but two speeds and it usually can only supply 40psi for idle, so it will mislead the gauge readings.
  14. Oct 3, 2020 at 9:38 AM
    BillsSR5
    bill
    2014 SR5
    you first
  15. Oct 3, 2020 at 9:40 AM
    Larzzzz
    Larry
    MA
    A voltmeter across the fuel pump wires will confirm the resistor operation then. Long leads into the cab, go for a drive and see what the meter does.
  16. Oct 3, 2020 at 7:31 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Definitely find another mechanic.
    Your first "mechanic" works by throwing parts at it based on guess. Good for his profit, bad for your wallet
    The next guy you need to be sure to ask "What is causing the problem?" and "What is the proof?"
  17. Oct 3, 2020 at 8:07 PM
    Goldwrench
    Goldwrench Well-Known Member
    2010 silver 4wd access taco
    Bought used and mild lift
    Not that familiar with the Toyota engines, but, had an old Dodge Ram 150 having same symptoms. Timing chain problem.
