Struggling with 12 mpg
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chandler, Dec 26, 2018.
  1. Dec 26, 2018 at 11:44 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
  2. Dec 26, 2018 at 11:46 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    But if he's not throwing codes after removing his catalytic converters then something is up...maybe his CEL bulb is burnt out
  3. Dec 26, 2018 at 11:47 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  4. Dec 26, 2018 at 11:48 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I think only the front ones are monitored, the ones that are built into the manifolds
  5. Dec 26, 2018 at 11:50 AM
    eon_blue
    Azusa, CA
    Ah that makes sense. I have a 1st gen so it's different for me I suppose, front or rear will toss a code if bad but we only have 1 or 2 cats depending on the model.
    b_r_o[QUOTED] likes this.
  6. Dec 26, 2018 at 12:03 PM
    dipstiktaco
    dipstiktaco Well-Known Member
    canada
    2006 TRD off road access cab auto URD supercharged
    There is no 02 sensor after the secondary cats on the first or second gen trucks so they will not throw a code if they're removed
    eon_blue[QUOTED] likes this.
  7. Dec 26, 2018 at 12:07 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The thing about these mpg threads is we really dont know about people's driving habits. one persons "moderate" throttle would make other people's jaws drop.
    A few things that I believe to be true...
    - if you're fond of driving down the freeway over 70mph forget about good mpg
    -you cant do jackrabbit starts off every stoplight either
    -check tire pressure often
    -try a different brand or octane of fuel for a few tanks and see if anything changes
    Also, a little scan tool is great for watching fuel trims. If the long term trims are high you could look at a sensor issue or fuel calculation issue (pcm is struggling to get fuel calc under control). if fuel trims are low/stable then the pcm is doing everything correctly and it's a safe bet to chalk it up to poor driving habits
    Best advice I've gotten is to drive like there is an egg under the gas pedal!
    Other than that, buy a Prius :rolleyes:
    Lester Lugnut and Fitz235 like this.
  8. Dec 26, 2018 at 12:11 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    You mean I cant do 80 down the interstate :eek:
    All joking aside, can you elaborate on the fuel trims? I have a ScanGauge and would like to look into those if it reads them out. What are 'normal' numbers?
  9. Dec 26, 2018 at 12:14 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    A good rule of thumb is anything below 10% is ok. Remember short term can jump around depending on load, going up hills, etc. Its the long term that really tells the tale
  10. Dec 26, 2018 at 2:33 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    My mileage got better with winter fuel. I think it is a California thing? Speed under 70 mph Max is also a way to increase mileage. Highway driving (constant speed) vs. city driving (stop & go) will give you higher mileage. 15 mpg city and 19 mpg highway are my common corrected mileage range, driving carefully. I have a 4WD V6 auto. DC, the worst mileage model.
    Pervy likes this.
  11. Dec 26, 2018 at 7:11 PM
    Chandler
    Chandler [OP] Member
    Chandler
    2006 tacoma 4x4 long bed trd
    It has a v6 4L
    had it for 4 months
    i fill up, reset trip meter, drive until close to empty, refill tank, divide mileage driven by gallons refiled.
    live in GA, small hills, ranging from 30-90 degrees, same on highway vs city driving
    tire size 265/75 R16
    stock gearing
    automatic
    mix
    i get about 220 miles out of 18 gallons
  12. Dec 26, 2018 at 7:19 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Is it supercharged?
  13. Dec 26, 2018 at 7:27 PM
    Chandler
    Chandler
    i wish
  14. Dec 26, 2018 at 7:41 PM
    Pervy
    Pervy Well-Known Member
    East Texas
    2.4 Tacoma, 3.4 4Runners
    Dang im pretty surprised how low and how common it is to be that low for a v6 2nd gen taco. Getting 12-14mpg city is close to what we get on the v8 Tundra. Something must be up lol
  15. Dec 26, 2018 at 7:58 PM
    #35
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yea but these trucks have never gotten good fuel economy
    Maybe we just didn't notice because gas used to be cheaper lol
  16. Dec 26, 2018 at 8:04 PM
    #36
    Flatout110
    Flatout110 Well-Known Member
    Tony
    Long Island, NY
    2019 Tacoma
    Engine oil By-pass filtration system. B&M transmission cooler Rustproofed
    What is the engine’ operating temperature after warm up? Should be somewhere between 200-215 deg F. Any temp lower than this will have a drastic negative affect on fuel mileage. A new quality thermostat should be installed.
    Toyko Joe likes this.
  17. Dec 26, 2018 at 9:22 PM
    #37
    David K
    Add 4% to the odometer.
  18. Dec 27, 2018 at 2:42 AM
    #38
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Do you have heavy aftermarket bumpers? How much extra weight are you carrying around like tools and crap. That will hurt your mpg? I have about 75 lbs of tools around every day and drive 100 miles a day for work up and down the nj turnpike and I still average around 17-19 depending on how fast I drive and heavy winds . I hope you find your soarce of your poor mileage
  19. Dec 27, 2018 at 4:02 AM
    #39
    Flatout110
    Tony
    Long Island, NY
    2019 Tacoma
    Most do not realize that fuel delivery is severely affected by engine temperature, I would change the thermostat and install a name brand 195 stat or an OEM stat. Also, can you verify that the PCM is going into closed loop? A simple scan tool should let you see this happening. Does the engine have any vacuum leaks? Has anyone tampered with the emission control system?Has anyone checked fuel pressure? Have the fuel injectors been replaced? MAF sensor reading properly? Approximately 6 grams per sec at idle and should rise smoothly with RPM . Hope this helps
    Toyko Joe, whatstcp and SR-71A like this.
  20. Dec 27, 2018 at 5:09 AM
    #40
    SR-71A
    Zack
    Southern Maine
    I get better millage than that out of my 2012 4.0L with E range tires (same size) and some extra stuff like a steel bumper and winch. I would say 17mpg average on a tank is about what I can expect.
    If you dont have a OBDII scan tool, I would recommend getting one. But in the meantime your dash temp gauge should read right dead center (~190 F) after 10-15 minutes. If you do get a scan tool, it would also be good to confirm that there arent any active codes or pending codes. Even if the check engine light isnt on
    BassAckwards likes this.
