Strut and shock recommendations?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco302, Aug 26, 2018.
  1. Aug 26, 2018 at 6:39 PM
    Taco302
    Taco302 [OP] Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    Took the truck in for tire rotatation/balance/alignment today and noticed the alignment was way off. I do not offroad and have not hit any deep pot holes. The repair shop suggested new struts and shocks and quoted me at $750 but i know i can do it myself for less.
    What brands for rear shocks and front struts do yall recommend. I was thinking of ordering from rockauto but let me know of any other trusted sites you know.
  2. Aug 26, 2018 at 6:54 PM
    tony2018
    tony2018 Well-Known Member
    bilsteins seem to be the go to.
    E30325 likes this.
  3. Aug 26, 2018 at 6:55 PM
    E30325
    E30325 Well-Known Member
    Nick
    2000 Tacoma TRD 5spd
    5100's and OME 881's, AAL and KM3's
    Should be able to do stock bilsteins yourself for like $400 or less
    FirstTimeFirstGen likes this.
  4. Aug 26, 2018 at 7:26 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    If you have the trd package go with stock bilstein 4600's, if not go with a kyb strut and shock.
    Taco302[OP] likes this.
  5. Aug 26, 2018 at 11:37 PM
    lalojamesliz
    lalojamesliz Well-Known Member
    Ed
    02 dbl cab V6 pre-runner trd
    Tundra brake upgrade (in progress)
    I just did this. I bought the blisteins on Amazon for $340.
  6. Aug 27, 2018 at 1:24 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Do you have your numbers ??
    Shocks and struts factor into alignment
    I installed my new springs and struts after my alignment had it checked again spot on.
    This is a trusted Shop you use all the time?
    Just because they have a Alignment Rack does not mean they know how to use it.
  7. Aug 27, 2018 at 3:54 PM
    Taco302
    Greenbow, Alabama
    Shocks and struts? Which bilstein kit should i buy for a 2003, 4wd extracab - no TRD?
  8. Aug 27, 2018 at 4:44 PM
    lalojamesliz
    Ed
    I Personally wouldn't know what to suggest but everyone here says the blisteins
  9. Aug 27, 2018 at 5:29 PM
    Taco302
    Greenbow, Alabama
  10. Aug 28, 2018 at 5:58 AM
    Tisoy281
    Tisoy281 Well-Known Member
    david
    Kerrville TX
    2002 PreRunner TRD, 2014 4Runner Limited 4x4
  11. Aug 28, 2018 at 2:25 PM
    Taco302
    Greenbow, Alabama
  12. Aug 28, 2018 at 2:29 PM
    Tisoy281
    david
    Kerrville TX
    I saw that also, and so did my mechanic, and he said it won't make a difference. I can let you know when they come in tomorrow and I get them installed.
  13. Aug 28, 2018 at 2:38 PM
    Taco302
    Greenbow, Alabama
  14. Aug 28, 2018 at 3:05 PM
    Tisoy281
    david
    Kerrville TX
  15. Aug 29, 2018 at 9:08 AM
    Tlrtucker
    Tlrtucker Well-Known Member
    2000 Tacoma TRD
    Front 5100's will lift your front 0-2 inches depending on how you set them up.
    Rear 5100's require a 1 inch lift in the rear, could be add-a-leafs, lift shackles, blocks, whatever... DO NOT use them on sagging stock suspension. You WILL tear them up.
    4600's are for stock height. This is likely what you are wanting.
    Pervy and Taco302[QUOTED][OP] like this.
  16. Aug 29, 2018 at 9:43 AM
    jenesaispas
    jenesaispas Hide your kids, Hide your wife!!
    Justin
    South East Wisconsin
    2002 Tacoma 3.4L V6 5 Speed Manual TRD
    I have an old 2001 xtra cab 4x4 TRD with no lift. I need new shocks and quick struts but I'm thinking the leaf springs are pretty saggy and need replaced as well. Any recommendations on replacement leafs?
  17. Aug 29, 2018 at 9:48 AM
    Tisoy281
    david
    Kerrville TX
    Damn... Seriously, I'll tear them up?
  18. Aug 29, 2018 at 9:58 AM
    Tisoy281
    david
    Kerrville TX
    Thanks for the info. Just ordered some 1 inch blocks and told my mechanic. He'll have to hold off til this weekend to install. Thanks for saving me a headache.
  19. Aug 29, 2018 at 11:15 AM
    Tlrtucker
    2000 Tacoma TRD
    Think about it, they're designed for a lifted vehicle - if you run them on stock suspension, even if it's not sagged (which they likely are if your springs are original), the shocks will bottom out on big bumps. Bottom out hard enough, or often enough, and what do you think will happen?
    If you're not looking for a lift, then go with the 4600's. No point going with the 5100's if you don't want a lift.
  20. Aug 29, 2018 at 11:21 AM
    Tisoy281
    david
    Kerrville TX
    I wanted to level out the front on the lowest setting, but since I'll be putting the 1 inch block in the rear, I'll go ahead and have him put it on the highest setting up front.
