Strut and shock recommendations?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco302, Aug 26, 2018.
  1. Aug 29, 2018 at 2:27 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    The highest setting for 5100s is more like 2.5". I would go middle setting for the fronts with the rear 1" higher.
  2. Aug 29, 2018 at 2:46 PM
    Taco302
    Taco302 [OP] Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    Yes, and the second set of links i posted were the 4600's...i'll go with them. I'll feel better when i click the "buy" button.
  3. Aug 29, 2018 at 3:24 PM
    Taco302
    Greenbow, Alabama
  4. Aug 29, 2018 at 3:30 PM
    Taco302
    Greenbow, Alabama
    I'd like some input on leafs as well.
  5. Sep 7, 2018 at 12:34 PM
    Tisoy281
    Tisoy281 Well-Known Member
    david
    Kerrville TX
    2002 PreRunner TRD, 2014 4Runner Limited 4x4
    Do you have any idea where I can find instructions on the rear block install? I've been looking everywhere and can't find anything.
  6. Sep 7, 2018 at 1:30 PM
    Tlrtucker
    Tlrtucker Well-Known Member
    2000 Tacoma TRD
    Nope. But it's not that difficult to figure out. Jack it up, put it on jack stands, remove the wheels, support the rear end, remove ubolts, lower axle, install 1" block, raise up rear end, install NEW ubolts, torque everything down appropriately, install wheels, jack up truck, remove jack stands, drink beer.
    If you can't figure that out, you probably shouldn't be doing it yourself.
  7. Sep 7, 2018 at 1:32 PM
    Tisoy281
    david
    Kerrville TX
    I could definitely do that, but don't have tools or space after downsizing. Truck is currently at a friends house who is doing the work, and the rear blocks are the last thing pending to go on. He was saying he needed a larger jack to get the rear up so the axle droops, but I was sure there is an easier way of doing it without a larger jack.
  8. Sep 7, 2018 at 1:33 PM
    Tisoy281
    david
    Kerrville TX
    I read that only one side should be done at a time also.
  9. Sep 7, 2018 at 3:41 PM
    jbrandt
    Justin
    I can't think of a reason to only do one side at a time. Probably easier if you do both at the same time, too.
    As for not having larger jacks, you can do it with wood blocks (search around for some tips on how to do that safely)
    Or just go to harbor freight and get some 6 ton jacks for like $50...
  10. Sep 7, 2018 at 4:47 PM
    GMack52
    GMack52 Well-Known Member
    Garrett
    Clermont, FL
    2001 Tacoma SR5 TRD
    bed liner, that's it for now
    Considering doing the same on my 2001 SR5 TRD. Any special considerations for the TRD model as opposed to the Bilstein 4600 set previously mentioned?
    Also, anything else y'all would consider changing out for newer parts for longevity while i'm down there?
  11. Sep 7, 2018 at 7:48 PM
    TacoJohn4x4
    TacoJohn4x4 Captain Save-A-Ho
    Central Valley
    2002 Tacoma DC 4x4
    Rockauto is the way to go if you just plan to drive your truck on the streets. Very inexpensive and works.
