Strut installation
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bryce Dahlstrom, Nov 15, 2022.
  1. Nov 15, 2022 at 5:40 PM
    Bryce Dahlstrom
    Bryce Dahlstrom [OP] Well-Known Member
    Bryce
    2003 Toyota Tacoma
    Just 1.25 inch spacers so far
    I’m installing new suspension and I’m finally ready to tighten down the bolts. Just curious should I use thread locker on these bolts or is the a reason I shouldn’t. Also just wanted to confirm that the upper bolts need to be torqued to 47 ft lbs and the lower bolt to 101 ft lbs.
  2. Nov 15, 2022 at 5:44 PM
    Bishop84
    Bishop84 Well-Known Member
    Nah, loctite isn't required or suggested, its not a fastener that vibrates loose.
    Just clean threads. I spray a little lube, which technically changes torque, but I just go hand snug with a standard wrench on the top hat and 4 uganugs on the bottom.
  3. Nov 15, 2022 at 6:58 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    My manual shows that those are the correct torque specs.
    I would not use any thread locker either.
    Bryce Dahlstrom[OP] likes this.
  4. Nov 15, 2022 at 7:04 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I put antiseize on mine and reduce torque by 15%.
  5. Nov 16, 2022 at 6:34 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    I have never used a torque wrench on those nuts. :notsure: I might work on my truck more than others though, so the coilovers probably come out a few times a year. Bottom line, not super critical. No thread locker. Don't strip them. You'll be fine. For sure put some anti seize on the lower bolt where it passes through the shock eye.
