Strut replacement for 2017 tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ryan0811, Nov 1, 2017.
  1. Nov 1, 2017 at 10:50 PM
    Ryan0811
    Ryan0811 [OP] Member
    2017 Tacoma SR
    looking to put on some 1.5 inch hub centric wheel spacers. As I put them on half the lug was not fully seated on the strut. Looking to replace the strut to a longer one. Does anyone have a chart or a website the tells me the demision before I take one off. My research has brought nothing. And has anyone put on spacers and run into problem and what did you do. Thanks
  2. Nov 2, 2017 at 7:19 AM
    Tacoroach
    Tacoroach Well-Known Member
    Vancouver, BC
    2017 DCLB
    Don't do it. Don't run cheap spacers if you decided to go this way. Go with Spidertrax or Bora. And I wouldn't recommend them bigger than 1".
    ICU1 likes this.
  3. Nov 2, 2017 at 8:15 PM
    modifiedtaco
    modifiedtaco Well-Known Member
    Alex
    2016 Magnetic Gray Tacoma Limited
    Tuff Country 3 inch spacer kit with aal Tuff Counrty 1/4" spacer on LF (for taco lean) Bilstein 5160 rear shocks Bilstein 5100 adj front struts (removed tuff country front spacers) set to 0 lift OME 886 coil springs Front sway bar relocation bracket N-Fab Rock Rails 17x9 -12 Fuel Beast wheels Toyo AT2 285/70/17 tires Led light conversion on all interior lights Morimoto 35w HID kit 5500k OE all weather floor mats OE Tonneau cover OE Door Sill Protectors Bed Mat De badged all factory emblems matte black vinyl tailgate letter and Tacoma emblem on door silver vinyl insert on glove box and door sill protectors OME Carrier Bearing Drop Insain Fab cab mount chop plates Weathtech Rain guards
    I'm confused.. so your look for hub centric wheel spacers and a longer strut? Did you mean stud?
  4. Nov 28, 2017 at 8:25 PM
    Ryan0811
    2017 Tacoma SR
    I have the spacer. The nut does not fit on the stud. The nut only goes down half way and not flush.
  5. Nov 28, 2017 at 8:44 PM
    modifiedtaco
    Alex
    which studs are the issue the factory ones or the new ones coming off the spacer? either way a spacer in general is not recommended. one that size or one with not enough thread engagement could possibly be dangerous..
  6. Nov 28, 2017 at 8:44 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
  7. Nov 29, 2017 at 6:21 AM
    kercmerk
    kercmerk Active Member
    2017 DCLB TRD Sport (w/ Tech Pkg) MGM
    Don't put wheel spacers on your brand new truck, just buy the proper offset wheels.
  8. Nov 29, 2017 at 12:49 PM
    Halena Molokai
    Halena Molokai Well-Known Member
    Black 2016 TRD DCSB OR 4x4 MT6
    BFG KO2 265/70/17 Moto Metal 17x 9 -12mm ToyTec Boss 2.0 lift Kit Wet Okole, Ceramic tint 35% Bakflip F1 Flowmaster Exhaust Single in /Dual out with 3"stainless tips DashMat Covercraft Custom windshield shade Tilt Alarm Weatherbeater Mats Diode Dynamic LED upgrade to interior OEM Bed Mat OEM 5" Chrome Side Steps
    OP, Let's start from the top and clarify what you are talking about. Lug nuts are what keep the wheel secured to the wheel hub. On a wheel hub there are typically 5 or six studs that the lug nuts bolt too. Your hub centric wheel spacer mounts to the wheel hub. Your wheel now mounts to your wheels spacer. Are the lugs to secure the Spacer not flush and the Spacer is loose?
