Strut Spacers
Discussion in '1st Gen. Tacomas (1995-2004)' started by blakeschoonover, Sep 12, 2018.
  1. Sep 12, 2018 at 9:58 AM
    blakeschoonover
    blakeschoonover [OP] Active Member
    Blake
    2003 Silver Tacoma TRD
    Radio
    So I have 2.5 lift struts and wanted to add a 3 inch strut spacer for more lift I know someone who had it done but just want to know if it works good or not or if I should just save up and buy a bigger lift kit thanks!
  2. Sep 12, 2018 at 10:06 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    No.
    Even if you have a pre-runner (no CV axles to worry about), this is a terrible way to lift the truck. Don't stack lifts. You end up exceeding the designed specifications of BOTH lifts.
    Get a 6" bracket style lift (Procomp, etc.) if you want that high of a lift.
    Sperrunner likes this.
  3. Sep 12, 2018 at 10:08 AM
    blakeschoonover
    Blake
    Radio
    Even if there is no strut spacer in there right now?
  4. Sep 12, 2018 at 10:13 AM
    jbrandt
    Justin
    Yes.
    I'm not talking about adding 2 different strut spacers, although that would be stupid too...
    You have a 2.5" lift from your coilovers (they aren't struts, tho) and want to add 3 more inches with a spacer.
    The geometry of the suspension simply can't handle that much of a lift. Your upper and lower A-arms will be at such an extreme downward angle it will be impossible to get it aligned, not to mention you'll destroy your CV joints.
    Get a bracket lift. And don't cheap out and get that one that costs $800 (I'm looking at you, Rough Country) when all the other ones cost $2k+. There's a very good reason it is so much cheaper.
    Clearwater Bill likes this.
  5. Sep 12, 2018 at 10:13 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    this aint it chief. I mean if you really wanted to yeah you can put a 3 inch spacer on your already lifted setup.
  6. Sep 12, 2018 at 10:17 AM
    Clearwater Bill
    Billy
    Largo Florida
    Is it 4wd?
    Is this lift to impress kids at the mall, or do you have a functional plan in mind?
    Side note. Tacomas don't have struts. They are coil-over-shock double wisbone front suspension. Regardless of the terms you may see in online ads. ;)
    2BeersPlease likes this.
  7. Sep 12, 2018 at 10:24 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    I think the actual issue would be getting it to align afterward. You'd never be able to get rid of the positive camber. If you want it to drive afterward, you should get a bracket lift. Or a 3" body lift would be cheap and get you taller.
    I lowered a 6 lug Tacoma so far be it from me to throw the first stone LOL- it's your truck do what you want.
  8. Sep 12, 2018 at 10:26 AM
    jbrandt
    Justin
    Good point about the intended use @Clearwater Bill
    If you want performance for off road, I will HIGHLY recommend you not get a huge lift. You will get far superior performance for off-roading from a well thought out set of coilovers and rear leafs to get you (at most) 3" of lift. That's all you need to fit 33's. If you want 35's, you'll need to do some serious :sawzall: and :welder:. All the 6" lifts do if make your truck have a higher center of gravity.
    The other "proper" way to get a little more than 3" (maybe 4-5") of lift is to go long travel. But again, that takes some serious fabrication and of course, $$.
    If you want the bigger lift for looks, that's cool too. But please don't stack your lifts. Get a lift that is designed form the start to achieve your desired result.
  9. Sep 12, 2018 at 11:13 AM
    blakeschoonover
    Blake
    Radio
    No I’m basically going off looks I want it look sharp but be functional and not go too cheap the lift was already on it but I didn’t know what kind has anyone looked into that 4” pro comp?
  10. Sep 12, 2018 at 11:14 AM
    blakeschoonover
    Blake
    Radio
    I’m kind of new to this so bare with me
  11. Sep 12, 2018 at 11:15 AM
    blakeschoonover
    Blake
    Radio
    It’s a pre runner no 4wd but 6 lug
  12. Sep 12, 2018 at 11:19 AM
    coopcooper
    alberta canada
    I don't think they make spindle lifts for 6 lugs but if they do that would be a decent way to go since your 2wd
  13. Sep 12, 2018 at 11:20 AM
    blakeschoonover
    Blake
    Radio
    Yeah I’m not into to all the over landing and what not plus I love my truck it’s only got 55,*** miles on a 03 so I don’t want to mess anything up on it
  14. Sep 12, 2018 at 11:42 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Do you like wheel bearings? I've seen a few 1st and 2nd gens where the strut spacers like wheel bearings to. Not sure why - have just seen it in person.
  15. Sep 12, 2018 at 11:58 AM
    jbrandt
    Justin
    Since you're a pre-runner, that does help things a bit since you don't have to worry about your CV angles.
    That said, even at 3" a lot of people end up needing aftermarket upper control arms (UCA) to get their truck aligned. The stock ones can be too short and you end up with really bad camber. After market UCAs will fix that, but only to a point. When you put shocks that are too long, or shock spacers like the pro comp and others have, you also run into an issue where at full droop the spindle can contact the coil spring (bad!).
    Hence why even the pro-comp 4" lift is a bracket style.
    https://www.procompusa.com/suspension-product-details.aspx?pt=3533&pl=1808
    But even then, all that does is throw a giant spacer in between your stock coilover and the shock tower and uses spacers between the upper control arm and the spindle (i.e. balljoint spacer). You will not see any performance improvements with this lift, despite what Pro Comp tells you. In fact, IMO, performance and durability decrease with that kind of lift. If you go this route, you must remove whatever "lift" is already on your truck, because this lift assumes you have stock coils.
    Honestly, I would focus more on getting some good performing shocks (adjustable coilovers like king, fox, icon), or even go with a kit like the OME 3" lift kit where you get ALL new springs, shocks and leafs for about $1200. It will perform better on and off road than the Pro Comp...
  16. Sep 12, 2018 at 1:29 PM
    Clearwater Bill
    Billy
    Largo Florida
    HeadStrong Off-Road likes this.
  17. Sep 12, 2018 at 2:09 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
  18. Sep 12, 2018 at 2:10 PM
    jbrandt
    Justin
    Ok... What's that?
