Strut swap went bad. Now my TACO handles aweful.
Discussion in '1st Gen. Tacomas (1995-2004)' started by zman21, Jan 4, 2012.
  1. Jan 4, 2012 at 3:29 PM
    zman21
    zman21 [OP] New Member
    Zack
    Houston
    01 PreRunner TRD
    Hi all,
    I took my truck to a local repair shop to replace original front Tokikos with Blistein. After they took out the struts and uncompressed the coil, they realized Blistein I brought has the wrong size :)eek:, my fault), so they put original Tokikos back to the truck. After that, the truck handles awefully. I hear noise from the suspension, steering is not precise as it used to be. Bumps are rougher than before.
    I would like to conclude that the mechanic did not put back the Tokikos properly (hurry up job). Or is it possible that he had mixed up left and right struts? Or do I just need an alignment to correct the handling?
    Please help. Thanks.
  2. Jan 4, 2012 at 3:33 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Welcome to TW.
    As long as it was put back correctly and all they did was remove the shocks/springs then put them back on you shouldn't need an alignment.
    As far as I know springs are never handed....shocks yes, but that's for remote resi.
    If your steering is loose check your tie rods and sway bar. Maybe they removed those and didn't put them back on correctly. Could be many many things when some garage messes with your truck.
  3. Jan 4, 2012 at 3:49 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    just get the right parts and have him finish the job...
  4. Jan 4, 2012 at 4:23 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    if he took the coilover apart, like he took the spring away from the shock? he might have put the coil spring back upside down.
  5. Jan 4, 2012 at 4:23 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    Sounds like something wasn't re-installed correctly.
    Maybe he accidentally flipped the coil perches :notsure:
  6. Jan 4, 2012 at 7:09 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    this is a distinct possibility
  7. Jan 4, 2012 at 7:30 PM
    zman21
    Zack
    Houston
    01 PreRunner TRD
    I think you guys are on the path to right diagnosis. Thanks. Is there any way to visibly tell the coil springs if they are reversed? The mechanic may deny that he did anything wrong.
  8. Jan 4, 2012 at 7:34 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    post up a pic
  9. Jan 4, 2012 at 9:16 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    If the spring perch is on correctly , it'll look like a "bell", & if done wrong it'll look like a ...well...an upside down "bell" ....haha:)
    Also check the config. on all grommetts/bushings/ retainer cups..
    make sure they're all there & just as important, make sure they're in the right order for proper assembly..
    For the record, I'm astounded by the number of "Legit" repair shops that are totally clueless as to the "rights" & "wrongs" of coil over struts....
  10. Jan 4, 2012 at 9:24 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    if the coil perch was flipped, wouldnt his front be riding high?
  11. Jan 4, 2012 at 9:43 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Well, probably so, but the issue would be a coil spring slopping around with compression/decompression because it isn't seated properly, not that the added preload helps any...
  12. Jan 4, 2012 at 10:03 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Aren't the perchs welded to the shock body on the Tokikos? :notsure:
  13. Jan 4, 2012 at 10:05 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    This I do not know senore~:notsure:
  14. Jan 5, 2012 at 6:09 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    Yes spring perches are welded on. No possibility of that mechanic flipping those haha. I know cause i have set sittin in my garage.
