Strut turning
Discussion in '5 Lug' started by 2.7taco, Jun 11, 2011.
  1. Jun 11, 2011 at 1:09 PM
    2.7taco
    2.7taco [OP] Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    Does a spring compressor need to be used to turn the struts 120 degrees for the fat bobs kit?
    I seem to vaguely remember that another 5 lugger owner here said he never used a spring compressor tool.
  2. Jun 11, 2011 at 6:48 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    i havent heard of anyone needing a compressor because the spacer goes on top of the strut not the spring and you slightly turn it to line up with the holes on the bucket
  3. Jun 12, 2011 at 12:06 PM
    2.7taco
    Texas
    I understand that the spacer goes on top of the spring, but what I don't understand how to rotate the strut so I can remount the lower part to the control arm. I'm guessing the brake line can remount without a problem.
    Has anyone run into any brake lines being too short after the lift.
  4. Jun 14, 2011 at 11:03 AM
    disc0monkey
    disc0monkey All right. I believe ya. But my Tommy Gun don't!
    I used a compressor.
  5. Jun 14, 2011 at 9:26 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    use the compressor put the lift on and lets see some pics :D
