Strut wont fit back in after spacer lift
Discussion in 'Suspension' started by Watcher One, Nov 30, 2017.
  1. Nov 30, 2017 at 1:10 PM
    Watcher One
    Watcher One [OP] Member
    2003 Toyota Tacoma Pre-Runner Step Side
    None
    vice grips just rounded it off even more before and still dont work. I have a dremel but the inside is spitting out sparks so its toast and using it further might prove disastrous. I dont know what to use guys. My reciprocating saw is way to big and just doesnt work. Could I hit it hard enough with like a chisel or screwdriver and hammer and break it you think?
  2. Nov 30, 2017 at 1:13 PM
    Skell
    Skell KORE
    Tony
    NE PA
    2015 DCSB, grey
    custom car grill, KORE sliders, light bar, KORE bed bars w/ tire and high lift mount. MOBTOWN front IFS skid.
    Tighten your vice grips up, get in there and use both hands to clamp the fuckers on. Grab a pair of channel locks if you have to to get them locked on.
    You could try a nut breaker
    https://www.homedepot.com/p/GearWrench-Universal-Nut-Cracker-715D/204625347?cm_mmc=Shopping|VF|G|0|G-VF-PLA|&gclid=CjwKCAiA9f7QBRBpEiwApLGUinIe0ylpkVc9X2xGDix3iG4la3mnriHlcLmOOt7858gsMGEU85iIWRoCJoIQAvD_BwE&gclsrc=aw.ds&dclid=CJyM-fSb59cCFQiZyAody8APWQ
    I think a chisel is just going to bend the shit out of the stud and the mounting plate it goes through.
    If you have access to an oxy acetylene torch, torch the fuckers off.
    tcjacado likes this.
  3. Nov 30, 2017 at 1:20 PM
    skullver
    skullver Well-Known Member
    Ventura, CA-Carpinteria, CA, La Conchita, CA.
    2006 Tacoma 4wd double cab, short bed, black. 2007 Sequoia SR5 Silver.
    Try some heat. If you don't have access to a welder, you could try and file down some of the sides of the nut and force the next size down SAE size socket(sacrificial) on there. I'm not sure how big your hands are or how much room is there. Good luck.
  4. Nov 30, 2017 at 1:22 PM
    Skell
    Skell KORE
    Tony
    NE PA
    2015 DCSB, grey
    Hes got three of them to get off tho, so he'd need three sockets. ++ how the fuck are you going to beat a socket onto that nut with the space were talking about?
  5. Nov 30, 2017 at 1:28 PM
    skullver
    If all 3 are seized that badly then he obviously isn't doing something right, like using a penetrant etc. And who said anything about beating it? A bit of patience is all. Calm down.
  6. Nov 30, 2017 at 1:32 PM
    Skell
    Skell KORE
    Tony
    NE PA
    2015 DCSB, grey
    You're going to grind the bolts down to get another sized socket to fit, any time ive done this ive had to hammer the sacrificial socket onto the bolt.
    He said he did use PB blaster, you can see it all over the top of the housing in the poor guys pictures. Stating "he's obviously not doing something right" isn't helping either.
  7. Nov 30, 2017 at 1:38 PM
    Watcher One
    None
    Alright guys im just gonna go hit up home depot and buy a torch and burn the sucker off. I dont know how long that torch will last so what do i do once its good and hot. Just hit it until it breaks?
  8. Nov 30, 2017 at 1:40 PM
    Skell
    Skell KORE
    Tony
    NE PA
    2015 DCSB, grey
    A torch from home depot isn't going to do it man. If you're trying to torch the bolts off you need an oxygen acetylene torch
    They are propane, this will heat things up perhaps get things to come loose.
  9. Nov 30, 2017 at 1:43 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    I would try a rounded nut remover. Just get a good one.
    Willbeck likes this.
  10. Nov 30, 2017 at 1:45 PM
    Skell
    Skell KORE
    Tony
    NE PA
    2015 DCSB, grey
  11. Nov 30, 2017 at 1:47 PM
    skullver
    I usually let the penetrant sit overnight(drenched) and rarely have this problem(just for future reference). If you can get a socket to fit on there tightly with some grinding/force etc, the heat might help break it free. I feel your pain.
    Good luck.
  12. Nov 30, 2017 at 1:49 PM
    20tacoma17
    2017 DCLB Sport AT
    I've been there, just don't know if they have deep extractor if he needs one? Heat might help but all that penetrate on there might not be good idea?
  13. Nov 30, 2017 at 1:51 PM
    Skell
    Skell KORE
    Tony
    NE PA
    2015 DCSB, grey
    Make sure you got a fire extinguisher handy. Playing with fire under a vehicle is always a bit risky.
    20tacoma17[QUOTED] likes this.
  14. Nov 30, 2017 at 1:52 PM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    get a better vice grip. you should be gripping it so tight that your hand kills trying to get it clamped on (and off afterwards for that matter). don't use crappy chinese vice grips.
  15. Nov 30, 2017 at 1:52 PM
    #35
    Watcher One
    None
    The stuff you guys are recommending they don't have in stock at my local store. And I need the vehicle back tomorrow. I started this at 8 am and it's now almost 5 where I'm at. Didn't think it would take this long and wasn't expecting my dremel to shoot sparks. Why won't that torch do the job. Not hot enough? And if I did get the right torch would it catch all tbat pb blaster and other lubricants on fire? As for using better vice grips, it's so rounded off that every thing slips off. Usually it slips off in an upward fashion. There just not enough space to get it on tbere any other way
  16. Nov 30, 2017 at 1:54 PM
    #36
    Skell
    Skell KORE
    Tony
    NE PA
    2015 DCSB, grey
    A propane torch will still catch all that shit on fire. A propane torch won't melt the steel, it will only heat it it. This may work to crack things loose anyway, but it's not a sure thing.
    ++ This
  17. Nov 30, 2017 at 2:09 PM
    #37
    20tacoma17
    2017 DCLB Sport AT
    Try auto parts for nut extractor.
  18. Nov 30, 2017 at 2:09 PM
    #38
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Following...
  19. Nov 30, 2017 at 2:20 PM
    #39
    Watcher One
    None
    I called advance auto and they said they have a kit (or rather just a special socket) that fits on the end of the socket wrench and I'm guessing just grips it pretty good. He said it's $26 so it better work. I'm just call out of work tomorrow and get this done if not tonight cause it's pitch black outside. Still might get the propane torch cause it's cheap and might expand it enough. I really didn't need this crap to cost me any more money but at least it just builds up my tool collection even more.
  20. Nov 30, 2017 at 2:25 PM
    #40
    20tacoma17
    2017 DCLB Sport AT
    Just something else I've done. If you have any room for a hammer and cold chisel, you can go on the side like you're trying to drive it around the right side. The chisel digging in and the tapping of the hammer will sometimes break it free.
