Strut wont fit back in after spacer lift
Discussion in 'Suspension' started by Watcher One, Nov 30, 2017.
  1. Nov 30, 2017 at 2:29 PM
    #41
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    First problem, loosen uca and pcs, Mark align cams. Strut will go right in. Stripped bolt, heat it, then a nice sharp chisel in the direction it will loosen or weld a nut on top
  2. Nov 30, 2017 at 2:56 PM
    #42
    Watcher One
    Watcher One [OP] Member
    2003 Toyota Tacoma Pre-Runner Step Side
    None
    I just went to home depot and bought a propane torch and a chisel. I'm just gonna try to burn it off and chisel it out.
  3. Nov 30, 2017 at 3:00 PM
    #43
    tcjacado
    tcjacado Well-Known Member
    Good luck op
  4. Nov 30, 2017 at 3:00 PM
    #44
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    I know these things suck but hope you get it. Try chisel first without heat.
  5. Nov 30, 2017 at 3:20 PM
    #45
    downhillbik3r
    downhillbik3r Well-Known Member
    James
    Carson / Big Bear
    2016 2.7L 4x4 5spd
    Kings, 4.88's, ARB, +2 LT, DMZ SUA
    Use your dremel with a cutoff wheel to cut a vertical slot in the nut and then smack it with something like a punch and a hammer to rotate it. This will allow it to break free. Also 50/50 acetone/atf mixture instead of PB blaster.
  6. Nov 30, 2017 at 3:48 PM
    #46
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    ^^What's "atf"?
  7. Nov 30, 2017 at 3:53 PM
    #47
    downhillbik3r
    James
    Carson / Big Bear
    2016 2.7L 4x4 5spd
    Automatic Transmission Fluid
    NMTrailRider[QUOTED] likes this.
  8. Nov 30, 2017 at 4:02 PM
    #48
    Watcher One
    None
    Well I tried to torch it and hit it with the chisel but it's so dark out I can't see anything so I'm going to try again in the morning. Plus when I torched it i was cooking a wire or some kind of line located behind that strut bolt pretty good and I don't know what's inside. Thought it might be some kind of ABS sensor wire. Also do you guys think that heating up that nut will damage the bolt in any way? Especially when I start hitting it with the chisel?
  9. Dec 1, 2017 at 5:22 PM
    #49
    Watcher One
    None
    Update guys, I got that nut off the bolt after several more applications of pb Blaster and a torch. Just stick a socket wrench on tbere and finally broke it free cause i think the socket also had a few jagged edges from hitting it with the chisel for it to grab a hold of. Used the same thing for some other rusted nuts and bolts for the rest of the project and got it all installed. I forgot to take a before picture but once it's daylight tomorrow I'll post a pic of it now. Thanks for all the help guys.
    Skell likes this.
  10. Dec 1, 2017 at 5:51 PM
    #50
    20tacoma17
    2017 DCLB Sport AT
    Glad you got it done...:thumbsup:
  11. Dec 1, 2017 at 7:06 PM
    #51
    Skell
    Skell KORE
    Tony
    NE PA
    2015 DCSB, grey
    custom car grill, KORE sliders, light bar, KORE bed bars w/ tire and high lift mount. MOBTOWN front IFS skid.
    Glad you got it man!
