Stub Antennas
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lentsnh, Jan 18, 2009.
  1. Jan 18, 2009 at 6:17 PM
    Lentsnh
    Lentsnh [OP] Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    If you have a aftermarket Sirius radio installed and you change to a stubby will it screw up your range and frequency
    edit: I have a Sirius antenna that makes the range better than a normal Sirius antenna
  2. Jan 18, 2009 at 6:29 PM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    is it not like a little square magnetic antenna on top?
  3. Jan 18, 2009 at 6:44 PM
    Lentsnh
    On top of the roof there is a small round Sirius antenna and then this guy at Best Buy put on a Antenna thing on the base of the car antenna to make it have better reception
  4. Jan 18, 2009 at 6:45 PM
    FlawedXJ
    Paul
    NorAla
    so a stubby fm antenna? I'm pretty confused as to what your asking. I have experience w/ gps antennas, xm, sirius, and fm antennas so i'll know what your asking as long as its clarified.
  5. Jan 18, 2009 at 6:51 PM
    Lentsnh
    Sorry about that.. I have the original OEM antenna and I thinking about getting a Stubby but the only problem is that my Sirius is aftermarket (Best Buy Tigertown did it).
    There is the normal Sirius antenna on my roof and then the guy at Best Buy put in a device to the OEM antenna to give the Sirius antenna (on the roof) better reception.
    If it will help you, Ill get pictures tomorrow
  6. Jan 18, 2009 at 6:53 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    I know what you're talking about -- switching to a stubby antenna won't affect it. The stubby is a lot thicker than the stock antenna, so it may not fit around very well.
    it's like the XM sure-connect. I have it installed on my DD
  7. Jan 18, 2009 at 6:54 PM
    FlawedXJ
    Paul
    NorAla
    edit: After reading delmarva's post I think now that your talking about a little c-clip that fits around the stock antenna so you can get better reception using an fm transmitter with your satellite radio.
  8. Jan 18, 2009 at 6:55 PM
    Lentsnh
    "so it may not fit around very well."
    What may not fit well? the stubby?
  9. Jan 18, 2009 at 7:03 PM
    Delmarva
    Tucson, AZ
    12 Tundra TRDRW
    The piece at the base of your FM antenna may not fit over the stubbie antenna very well as the stubbies are very thick. I'm basing this on how I installed my XM on my DD with the 'signal booster.'
  10. Jan 18, 2009 at 7:08 PM
    Lentsnh
    Yes!!! thats it. Exactly
  11. Jan 18, 2009 at 7:09 PM
    Lentsnh
    There we go, Were ALL on the same page now.
    so do i go to BB to get a bigger one?
  12. Jan 18, 2009 at 7:09 PM
    FlawedXJ
    Paul
    NorAla
    it will not fit on a fatter stubby. My dad had that w/ his xm and I tried borrowing it on my chevy ( i put a stubby on it) and it did not fit.
  13. Jan 18, 2009 at 7:10 PM
    Delmarva
    Tucson, AZ
    12 Tundra TRDRW
    I'm not sure if they have a bigger one, but ya can always check... :D
  14. Jan 18, 2009 at 7:11 PM
    Lentsnh
    so do i trash it? or make/get a bigger one
  15. Jan 18, 2009 at 7:12 PM
    FlawedXJ
    Paul
    NorAla
    buy the ipod adapter from me and you can plug in the headphone adapter directly into the ipod adapter (has a 3.5mm port on it.)
    Problem solved
  16. Jan 18, 2009 at 7:12 PM
    Lentsnh
    they have to because no one OEM antenna is the same thickness. (except a few):D
  17. Jan 18, 2009 at 7:17 PM
    Delmarva
    Tucson, AZ
    12 Tundra TRDRW
    Naturally, check for it to see if there's one that will fit. My DD has an automatic antenna that I disconnected -- it's about as thick at the bottom as my stubby on my truck. The C clip didn't really fit, so I jammed it on and taped it into place with electrical tape. Then, I put some shrink tubing around it -- not the greatest thing in the world, but it works... :thumbsup:
  18. Jan 18, 2009 at 7:21 PM
    Lentsnh
    sounds good to me. Any thing works when it comes out of your own mind
