Stubborn gas cap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bagster, Mar 6, 2012.
  1. Mar 6, 2012 at 3:33 PM
    bagster
    bagster [OP] Well-Known Member
    The gas cap on my 2010 Prerunner is getting hard to remove. I always tighten to the first click as advised, but it seems like every time I fuel up, I have to exert more force to remove the cap. Anyone ever have this problem?
  2. Mar 6, 2012 at 3:36 PM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    Make sure the fill tube is clean then put one or 2 drops of oil on the seal and spread it around.
    Should take care of it.
    See this quite often.
