Stuck- 1 wheel spins (2007 Auto LSD)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ds46000, Nov 14, 2020.
  1. Nov 14, 2020 at 1:40 PM
    ds46000
    ds46000 [OP] Well-Known Member
    07 PreRunner TRD Sport
    Question for you guys. Got stuck today crossing a small ditch. As soon as 1 rear (passenger side) wheel went in the air, just spins & the one with traction wasnt doing anything..
    2007 Sport with Auto LSD
    Im assuming there are clutches in the rear end, does this indicate they are bad?
    Would pressing the emergency brake to simulate traction with the wheel in the air done anything to help?
    Just trying to understand the limitations as i had to have someome pull me out.
    Thx
  2. Nov 14, 2020 at 1:45 PM
    Hooligans
    Hooligans Well-Known Member
    Fairbanks, Alaska
    2015 4x4 2.7/5spd.
    Still thinking about it.
    I have used the parking brake in that manner and it can be of some use on a 2WD with open diff. Not sure about your other question... seems the LSD should have helped.
  3. Nov 14, 2020 at 2:57 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Yes, I would expect a little help from the parking brake would help.
  4. Nov 14, 2020 at 3:07 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    You have an open diff , as others have mentioned pull the e - brake out (5 clicks) . This will allow your axle to feed equal power to both rear wheels
  5. Nov 14, 2020 at 3:54 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    In my experience a limited slip diff is quite limited in how helpful it is. Using the parking brake, or allowing traction control to work will help in some situations. But this is the most extreme situation. If you had 4X4 then the front wheels could have helped. Otherwise nothing less than a locking rear diff would help with this. Nothing wrong with the truck, you just exceeded it's capabilities.
  6. Nov 14, 2020 at 3:57 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Used my ebrake in a tough situation, today B710095F-A730-4FE5-AE5D-F860F669AD64.jpg I’m bad :oops:
  7. Nov 14, 2020 at 5:06 PM
    ds46000
    Thanks guys, good to know. Appreciate the info.
    Steves104x4 likes this.
  8. Nov 15, 2020 at 6:22 PM
    4WD FTW
    4WD FTW Well-Known Member
    '08 DC LB 4x4
    Icon Suspension Kit Pelfrey Bumper and Skid 4.56 Gears Detroit TruTrac Rear Archive Hammer Hangers Deaver U402 Stage 1
    Mine has always done that as well. When I regeared I put in a Detroit True Trac which is like a limited slip but supposedly better and without clutches that wear out. I did it thinking the LSD clutch pack might have just been bad. The true trac does help, in the sense that often both wheels turn now in a burnout instead of just doing a one wheel wonder, but I'll still lose power to a wheel if it's completely in the air. It chatters a bit if I'm gassing it hard while making a turn from a stop though. In case you were thinking about upgrading the limited slip
  9. Nov 15, 2020 at 6:54 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    if im not mistaken only 09+ trucks had auto lsd.
    05-08 trucks had the actual mechanical clutch pack LSD that do wear out over time.
    4WD FTW likes this.
  10. Nov 15, 2020 at 7:21 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    You have found the limit of your limited slip. Whether it's electronically brake actuated, clutch type, gear type, etc. there is a limit to its effectiveness. Any mechanical style is useless once one wheel has zero traction as they need some grip at both wheels to function. This is why LSD's are great for performance at speed on roads and tracks both pavement and dirt. Electronic brake actuated systems can work with zero traction at a wheel but it must be very aggressive and it can be very hard on your brakes. For every ft*lbf that system gets to the wheel on the ground it must "waste" the same amount against the opposing brake. It's rough on your equipment thus most systems aren't tuned that aggressive. When terrain is rugged, traction is low, and getting all available torque to wheels with grip is at a premium, it's time for a real locker.
  11. Nov 16, 2020 at 5:40 PM
    ds46000
    Thanks for the info.
