Stuck access cab door on passenger side
Discussion in 'Technical Chat' started by Graham.s, Jun 16, 2020.
  1. Jun 16, 2020 at 10:19 AM
    Graham.s
    Graham.s [OP] Member
    Graham
    06 manual blue taco
    I have a 2006 tacoma access cab. About a month after buying it i closed the access cab door on the passenger side and it hss never been opened again.
    I assume the mechanism inside the handle just got disconnected and i just need to reconnect it, but to do that i need to take the door card off, and to do that I need to open the door.....i think you see my point.
    Anybody ever have this issue?
  2. Jun 17, 2020 at 5:46 AM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    Have you tried a "slim jim" yet? Obviously use it to grab the open mechanism instead of the unlock mechanism. I'm not 100% sure this is truely possible, but would make for an easy access if it is. (see what I did there? ):hattip:
  3. Jun 17, 2020 at 5:50 AM
    VirusCage
    VirusCage Well in the secondary immune response
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 1995 Landcruiser 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    Sorry, don't have an access cab, but had this happen on a couple previous vehicles. Do NOT cut a hole in the door panel trying to fix it...damned 1989 buick. Like stated above a slim jim down onto the actual mechanism/rod is probably your best bet
  4. Jun 17, 2020 at 5:08 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    I want to hear the story about a hole in a buicks door panel.
  5. Jun 17, 2020 at 7:27 PM
    VirusCage
    Bruce
    Allison Park, PA
    Thread jack...sorry
    Bought a shitbox 89 Buick Electra. I was taken by the red velour interior. This was in about 1997/1998. What a heap of shit. The Drivers rear door would stick a little and the electric locks would not unlock it. So 17 year old me decided to "fix" it. I fiddled with the the stricker/jamb and slammed it shut. Well, it wouldn't open anymore. After the gas tank, the rad, and the brake lines started to leak, I figure what the hell...I will fix that damn door.
    Sawzall in hand I guessed where to cut and went to town. Trim shattering, red fuzz (velour), faux wood everywhere and then...The resistance. The saw stopped cutting easily. Well I can't be told no, I went harder...
    Too hard...cut the wires and arms for the regulator, and crash goes the window.
    I got the door open, but at such a cost.
    Bronsky and 6 gearT444E like this.
  6. Apr 14, 2021 at 5:50 AM
    Bronsky
    Bronsky Member
    I have a stuck door in my driver side extended cab door. My search brought me here. The Buick story was so great that I forgot about how frustrated I am not being able to open the extended cab door.
