Stuck at Crossroad: Solid axle front 3rd gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wixo, Jan 28, 2022.
  1. Jan 28, 2022 at 3:29 PM
    Wulf
    rock raisin
    I'd check behind the dumpster at the dealership, best kept secret
    CygnusX191 and Wixo[QUOTED][OP] like this.
  2. Jan 28, 2022 at 3:29 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I think solo or someone has some 60 ifs hubs you can use as parts
    Wixo[QUOTED][OP] likes this.
  3. Jan 28, 2022 at 3:30 PM
    mhornco
    mhornco Well-Known Member
    Like my old wooden go cart with a front axle. Just weld a pin to the center of the diff the metal and mount that to plate you have welded to your truck. Attach a rope to each of the old spring mounts. Then you run the rope through each window and wrap them around your steering wheel. Pulling the ropes give you left and right turning plus you now have a solid axle mount. Not only that since it only attaches a one point why not make that a universal and you have unlimited flex on your front end now.
  4. Jan 28, 2022 at 3:35 PM
    Wixo
    Wixo [OP] Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
  5. Jan 28, 2022 at 3:42 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    12 inches. Talk about overcompensating
    Junkhead, MalinoisDad and CygnusX191 like this.
  6. Jan 28, 2022 at 3:42 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    With 12” of lift, you can easily fit 2.5 ton front and rear steer axles out of a Duce and a half. Hydraulic steer, pump in engine bay.
    Junkhead and CygnusX191 like this.
  7. Jan 28, 2022 at 3:48 PM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    Can you separate you brakes to each side and turn it into a true skid steer? @5nahalf has some tires for you.
  8. Jan 28, 2022 at 3:52 PM
    philth
    philth .
    My thoughts exactly.
  9. Jan 28, 2022 at 3:54 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    As long as you use the truck to go straight to work and back, it will be fine.
    miamijime, 3Six, wilcam47 and 3 others like this.
  10. Jan 28, 2022 at 3:55 PM
    Wulf
    rock raisin
    Don't forget that you'll need to build a truss for your 4 link setup to attach to
    CygnusX191, Slashaar, slander and 2 others like this.
  11. Jan 28, 2022 at 3:59 PM
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
  12. Jan 28, 2022 at 4:14 PM
    eurowner
    eurowner Duke Sky
    Scoty
  13. Jan 28, 2022 at 4:59 PM
    jdjones
    jdjones Well-Known Member
    2022 TRD Off-Road DCSB
    ColoradoTJ and CygnusX191 like this.
  14. Jan 28, 2022 at 5:16 PM
    dezert.taco
    dezert.taco Well-Known Member
    Nate
    Northern Nevada
    2018 Tacoma
    Excited to see how the front driveline will mount up.
    90yota, wilcam47 and CygnusX191 like this.
  15. Jan 28, 2022 at 5:17 PM
    #35
    Wulf
    rock raisin
    Notched oil pan in the works
    wilcam47, eurowner and Slashaar like this.
  16. Jan 28, 2022 at 5:21 PM
    #36
    JKO1998
    Utah
    Oil pan Delete
  17. Jan 28, 2022 at 5:27 PM
    #37
    C-Rok275
    C-Rok275 Well-Known Member
    2017 TRD Pro
    6112/5160s with Icon stage 2 leaf’s.
    If you’re stuck there I feel like your friend being a talented fabber/welder and you being you isn’t going to cut it.
    CygnusX191, Slashaar and Wulf like this.
  18. Jan 28, 2022 at 5:54 PM
    #38
    Wulf
    rock raisin
    Maybe clocking the engine so the oil pan is on the side would work
  19. Jan 28, 2022 at 5:57 PM
    #39
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Mount a lazy Susan from the home store on top of that and you’ve got steering
  20. Jan 28, 2022 at 5:59 PM
    #40
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    This
    CygnusX191 likes this.
