stuck axel nut
Discussion in '1st Gen. Tacomas (1995-2004)' started by rugis, Nov 19, 2012.
  1. Nov 19, 2012 at 6:51 PM
    rugis
    rugis [OP] New Member
    upstate NY
    TACOMA SR5 2.7L
    Hi all...new here and first post.
    OK here goes...
    I am working on replacing a bunch of front end joints including the front half axels, but I have been unable to remove the axel nuts. The cotter pin and safety(?) nut are moved. Soaked in PB blaster all day. I have a breaker bar with a 7ft pipe on it and that nut will not move. I have never seen something like this. Its not like its all rusted up either and I'm torqueing counter clock wise. Any ideas? :confused:
  2. Nov 19, 2012 at 6:55 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Propane torch to heat it, should come right off.
  3. Nov 19, 2012 at 7:35 PM
    rugis
    upstate NY
    TACOMA SR5 2.7L
    Sorry I forgot that I heated the nut best I could with a MAP gas/O2 brazing torch. Almost got one part of it red hot.
  4. Nov 19, 2012 at 7:37 PM
    dad32509
    dad32509 Thinking of something clever
    Dave
    San Diego
    Blacked out 05
    5100's front and back, OME 885x's, LR UCA's, OMD rear springs, Pioneer AVH-P2300DVD, HVAC Green led's MOD, Blacked out bumper, Plastidip emblems, custom front tube bumper, 32" combo led bar, rigid duallys, otrattw switches, my own Satoshi grille, shorty antenna, Spyder LED halo headlights. csjumper2003 map/dome, 3rd brake, DTRL white/amber and parking LED's. Pelfreybilt IFS skid, Cab mount chop, sliders and rear light bar w/blitzpro 5LR dust light. Uniden CB, Magnaflow 18" exhaust, Rear tire carrier, sway bar removed, spidertrax 1.25" spacers, Wheelers 16" Alloys w/265/75r16 Goodyear DuraTracs
    I was going to say X2, but now Im at a loss
  5. Nov 19, 2012 at 7:51 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Impact?
  6. Nov 19, 2012 at 7:54 PM
    GATORTACO92
    GATORTACO92 Well-Known Member
    Alex
    Hoover, Al
    2004 F-350 6.0 King Ranch
    2004 F-350...uh lots of motor work to go fast...er. Way to much to list. 2001: 3" leveling kit, ARB bumper, lightforce 240 blitz, 35" KM2s. SOLD 2008: OME 886s 90000 with dakars, LR UCAs, 5% tint, Satashi. SOLD 2015: Flooded and Gone
    try tapping the back of the hub to loosen the tension??
  7. Nov 19, 2012 at 7:59 PM
    ak47dennis
    ak47dennis Well-Known Member
    dennis
    Pa
    TRD
    Correct, propane does not get hot enough, map or O2 work great.
  8. Nov 19, 2012 at 8:10 PM
    00TRD4x4
    00TRD4x4 Active Member
    Brian
    KY
    rebuilt '00 Tacoma 4x4 3.4 5 speed TRD SR5
    K&N Cold Air Intake and filter, 3" body lift, 15" MT Sidebiters, 33/12.50 Cooper Discoverer st/t, Bushwacker wide fender flares, Brush guard, 2 hella lights, Cats gutted and cut out. Wish i had money for a SAS.
    Dont be sayin this shit.. lol i gotta replace both my cv axles this weekend...
  9. Nov 19, 2012 at 8:27 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    If you are just replacing the axles, buy new axle nuts to go along with the new shafts, and cut the nut off. If it's not moving with you yanking on it with a 7ft cheater, no amount of heat, impact gun, or lube will be the magic trick you need. Cut off the end of the shaft as close to the nut as possible, then split the nut in half on 2 sides of it with out touching the hub, then beat that nut off with a cold chisel. Good luck
  10. Nov 19, 2012 at 9:43 PM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    Yayyya! No fucking around, eh? Say hello to my little friend.
  11. Nov 19, 2012 at 9:48 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    All else fails, time to get tough
