Stuck between sliders
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JeffBoyardee, Nov 21, 2019.
  1. Nov 21, 2019 at 12:16 PM
    JeffBoyardee
    JeffBoyardee [OP] Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    Same price for weld on? I'm really back and forth due to price, only because I live in FL and they'd really be put to the test maybe a few times a year. But at the same time, one good "use" would make then worth the $$.
  2. Nov 21, 2019 at 12:35 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    I think a little cheaper. If you want to call or text you can
    Bannerman likes this.
  3. Nov 21, 2019 at 12:38 PM
    JeffBoyardee
    Jeff
    Seminole, FL
    will do
  4. Nov 21, 2019 at 1:12 PM
    badger
    badger Well-Known Member
    07 SR5
    Can you produce a certified quality weld on your back and around a corner, under a truck? Can you get to the inside of all your welds, wire brush them, and recoat the frame to prevent rust? If not, get a bolt on. There is no downside to a bolt on slider, only upside.
    Bannerman and ovrlndkull like this.
  5. Nov 21, 2019 at 1:20 PM
    JeffBoyardee
    Jeff
    Seminole, FL
    The individual doing the welding can.
  6. Nov 21, 2019 at 2:29 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    The OP lives in Florida so this doesn't apply but for those in the north beware. Weld on sliders will give Toyota a valid reason to exclude your truck from the frame replacement.
  7. Nov 21, 2019 at 2:47 PM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    You're probably better off with bolt on sliders. I can't remove the weld on sliders without cutting all the tubes welded to the frame. I'm used to them, so it doesn't bother me. I had to put some of the anti skid tape on them after I slipped on them when it was wet.
  8. Nov 21, 2019 at 2:58 PM
    JeffBoyardee
    Jeff
    Seminole, FL
    Pretty sure I'm gonna spend the extra $ and go with the SOS. Eddy did me right on a skidplate, so I don't mind supporting that type of business.
    badger and ovrlndkull like this.
  9. Nov 21, 2019 at 3:08 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    :thumbsup::headbang:
  10. Nov 21, 2019 at 3:42 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    I personally believe bolt on are stronger than weld on. Bolting provides clamp force so you have static friction from a large portion of the mating surface transferring force from the slider to the frame. With welded the forces are transferred only through the beads for significantly higher local stresses on the frame. Also everybody thinks they're either the best welder on the planet or "their guy" is the best welder on the planet but the truth is that it's a variable in the quality whether you like it or not, buildings have fallen down because of this kind of thing. In the end it probably doesn't matter, but one you can easily remove.
    But then again you can save on money because weld on are cheaper.
  11. Nov 21, 2019 at 4:55 PM
    badger
    07 SR5
    Looks like good stuff!
