Stuck bolt changing radio
Discussion in 'Audio & Video' started by nirvanas_chiv, Jul 26, 2024.
  1. Jul 26, 2024 at 9:32 AM
    nirvanas_chiv
    nirvanas_chiv [OP] New Member
    2008 red Tacoma
    Stock
    Tldr, I'm changing the original 2008 radio out as it's broken. There's an original bolt holding the faceplate to the dashboard making this an impossible feat to swap the radio. It will spin, but does not come out. What should I do? How do I get this out?
  2. Jul 26, 2024 at 9:38 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Faceplate? The OEM radio is held in the dash with four bolts behind the A/C control panel. Is it one of those four bolts?
  3. Jul 26, 2024 at 9:39 AM
    nirvanas_chiv
    2008 red Tacoma
    Stock
    Yes, it is. Do I need to remove all four, or just the top two, or the bottom two? Doing this off of a YouTube video.
  4. Jul 26, 2024 at 10:19 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Need to remove all four. There are two metal brackets which go up and cradle the radio, two bolts per bracket. If a bolt just spins, a rivnut or weld nut may have broken free from its retention feature. Cleanest way is probably to pull the center console, so you can reach behind the dash with pliers.
  5. Jul 26, 2024 at 10:20 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW..
    3JOH22A likes this.
  6. Jul 26, 2024 at 11:42 AM
    nirvanas_chiv
    2008 red Tacoma
    Stock
    Thank you. I ended up taking it to a shop to get it removed. It was cross threaded and had pulled the bracket it screws into loose, so I wasn't going to get it off on my own with the skills and tools I have.
