Stuck Bolt Leaf Springs
Discussion in 'Suspension' started by Drklude, May 30, 2009.
  1. May 30, 2009 at 5:27 PM
    Drklude
    Drklude [OP] Member
    Colorado Springs
    2017 TRD Off Road
    First I let me outline my situation. I have a 2000 4x4 tacoma whose leaf springs have broken...not that uncommon. I ordered some replacement shocks and springs from wheelers and they were wonderful, quick shipping good communication. I get the shocks on with a little elbow grease and move on to the leafs. I start tackling the U bolts and soon realize the project is going to suck as most of the bolts were quite rusted, I even sheared off two of them, and broke two socket wrenches but I'm getting replacements and moving past that. I've hit a wall with the bolt that runs through the front bushing and secures the leaf to the frame. I've unbolted it, but it absolutely refuses to move when I try to knock it out of the bushing. I soaked it in WD40, used a 3 foot metal pipe on the wrench for leverage, hell I even climbed under and hit the end with a sledge a couple of times, and all I got was a shower of rust flakes.
    Does anyone have any ideas/expierence dealing with these bolts that seem to have rusted/welded themselves in place??? Any and all help would be greatly appreciated.
  2. May 30, 2009 at 7:45 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    maybe try soaking them in PB Blaster for a day. That stuff works great!!!
  3. May 30, 2009 at 9:47 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i had to use a torch and cutoff wheel to get the main eye bolts out for my springs.....had to cut them bastards out. keep soaking it in pb blaster...but if that doesnt work, you will probably have to cut them out.
  4. May 30, 2009 at 9:49 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    pb blaster ftw.... if that doesn't do it then you'll have to cut em out
  5. May 30, 2009 at 9:55 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Cut em off, you need to replace them anyway. End the knuckle busting headache now and move onto the fun part of putting the truck back together.
  6. May 30, 2009 at 9:57 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep....thats what i'd do.
    just use a cut off wheel.........go across the bend in the spring that goes around the bolt, then it should break free.....cut the old seized rubber bushing out, and the bolt will come out. then you can either reuse and use some anti seize on it, or get new main eye bolts.
  7. May 31, 2009 at 5:58 AM
    Drklude
    Drklude [OP] Member
    Colorado Springs
    2017 TRD Off Road
    Thanks for all the advice. I guess I'll just cut the dam thing, sounds easier and it will make me feel better haha.
  8. Jun 2, 2009 at 8:32 AM
    Drklude
    Drklude [OP] Member
    Colorado Springs
    2017 TRD Off Road
    I went ahead and cut off the bolts, it was quite cathartic. Once I had the springs off and got a closer look at how rusted the bolts were it became quite clear that they would have been impossible to get out. Now waiting on the new parts from wheelers and the joy of reassembly. Thanks for the advice.
  9. Jun 2, 2009 at 9:32 AM
    22b22
    22b22 Well-Known Member
    Northern California - East Bay
    03 DoubleCab PreRunner TRD SR5
    OME 881/N91S - front Wheeler 5-pack/N85 - rear
    I started hitting mine with PB last night and hope they won't be that bad. They don't look that bad...
  10. Jun 2, 2009 at 9:55 AM
    Drklude
    Drklude [OP] Member
    Colorado Springs
    2017 TRD Off Road
    Mine didn't look terrible, but once you try to actually turn them and get them out its a whole different story. Sometimes the frustration isn't worth the money you save.
  11. Jun 3, 2009 at 7:48 AM
    thenrie
    thenrie Well-Known Member
    Stafford, VA
    2000 Tacoma, SR5, TRD, 2.7L (LEV), 4wd, 5sp m
    Magnaflow cat and cat-back exhaust, AFE Stage 2 cold-air intake system, 2.5" lift via Skyjacker leaf packs, Bilstein 5100s.
    I ran into the same problem. I found a reciprocal saw (sawsall) to be a simple, if not elegant, solution. Cut the bolt like butter. Be careful not to cut the perch. The replacement bolts are $6 from Toyota...or you can get grade 8 bolts from Home Depot for about $2.
  12. Jun 3, 2009 at 9:52 AM
    22b22
    After the first PB Blaster dried, I went out a few hours later and hit them all again with it - the nuts and bolts look like new and they had no visible rust prior, they just look clean and hopefully unstuck. I'll keep hitting them with PB twice a day until Sat and hope for the best. It's good to know Home Depot has replacements as I can jog to the one a mile and a half from my house.
  13. Jun 3, 2009 at 9:57 AM
    allupinsydeyou
    allupinsydeyou Well-Known Member
    so cal / vegas
    v8 swapped yota. dyno tuned @ 400hp
    modified total chaos uppers and lowers... king coilovers, deaver leafs, full cage, 351w motor swap, etc..
    just make sure you get the fine thread ones from home depot with the ny-loc nut. dont cheap out. they are worth it. it is what ive used on my suspension and for countless race cars and trucks. i snapped my spindles in half before the bolt even thought of moving.
  14. Jun 3, 2009 at 10:12 AM
    22b22
    Grade 8, fine thread. Check! I know the nut strength should match, I assume they have G8 nuts too?
    In this application, I don't think the nuts have to be as strong though as it's not a compressive load that I should be worried about, but the shear strength of the G8 bolt, right?
  15. Jun 3, 2009 at 10:18 AM
    allupinsydeyou
    so cal / vegas
    pretty much. but the g8 bolts you will never have a issue with. you can go balls out and get f-911 bolts. (aircraft grade) but those are some serious coin and not worth it for a stock truck that isnt seeing some SERIOUS bashing. technically grade 5 would prolly work for you but those bolts always seem to be semi-pitted and very very porous. just stick with the g8's and the ny-lock nuts. you will never have a issue. ill also suggest a g8 washer on the outside of the hangar on either side.
  16. Jun 3, 2009 at 10:22 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    If you're buying hardware anyway it's best not to knowingly install a weak link in something like this. Go for the grade 8 nuts.
    And as mentioned before, get ones with the nylon lock ring incorporated into the nut to keep it from backing off.
  17. Jun 3, 2009 at 10:24 AM
    allupinsydeyou
    so cal / vegas
    exxaccctly. i have some 11.5 inch long 3/4 inch diameter fine thread g8's i can mail you if you need them hahahahaha.
  18. Jun 3, 2009 at 10:25 AM
    22b22
    I don't remember seeing them there, so I figured I'd be paranoid and check it out ahead of time to see if it's OK to go with G5.
    Definitely going nylock style. Thanks again.
  19. Jun 3, 2009 at 10:34 AM
    allupinsydeyou
    so cal / vegas
    no grade 5! no no no. those suck nuts.
  20. Jun 3, 2009 at 10:40 AM
    22b22
    I wouldn't skimp on the bolts in this application, just checking on the nutz in case they didn't have them in stock.
    Worst case would be G5 nutz for a week until I could get the right ones and swap/re-torque.
