Stuck Brake Lights
Discussion in '1st Gen. Tacomas (1995-2004)' started by bruceirvin01, Sep 21, 2019.
  1. Sep 21, 2019 at 10:31 AM
    bruceirvin01
    bruceirvin01 [OP] New Member
    Bruce
    2001 Standard White Tacoma
    My Tacoma is a base 5 spend manual trans. I've had to remove the 10amp fuse! There seems to be a whistling sound that fluctuates as I depress the brake pedal!
    Suggestions?
  2. Sep 21, 2019 at 11:02 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Which 10-amp fuse did you have to remove, and why did you have to remove it?
    Maybe you have a leak inside your power brake assist?
  3. Sep 21, 2019 at 11:28 AM
    bruceirvin01
    Bruce
    The fuse box inside the cab dash. I removed it because the brake lights would still be lit!
