Stuck CD - Entune Premium
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mthopton, Aug 4, 2016.
  1. Aug 4, 2016 at 1:47 PM
    mthopton
    mthopton [OP] Well-Known Member
    ‘03 TRD Prerunner, ‘16 TRD DCSB 4x4 - gone, 24 TRD OffRoad
    As the title says, my favorite Bluegrass CD will notake eject. Any tips for getting a CD unstuck?
    My dealer is willing to order a new head unit if necessary but that seems overkill.
    Thks
  2. Aug 4, 2016 at 2:13 PM
    mbarbay
    mbarbay Well-Known Member
    Baton Rouge, LA
    2016 Tacoma BBP DCSB LTD 4X4
    is it trying to eject at all? like is the eject going through the sequence, like stopping play, and making sounds as if it is trying to eject, but cant, or is it just nothing....if its trying to eject but the disc is sliding instead of catching on the rubber grommets that push it out, then maybe some really small needle nose can pull just enough for the disc to catch. other than that there isn't too too much you can do...replace the head unit and buy a new replacement disc. good luck
  3. Aug 4, 2016 at 2:14 PM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    Try unhooking the battery might reset something.
    Modesto Tacoma and DukesTaco like this.
  4. Aug 4, 2016 at 2:18 PM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    Or slap it real hard.
    smitty99 likes this.
  5. Aug 4, 2016 at 2:22 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Sometimes there is teeny tiny hole you push a paper clip in to release it.
    Did the CD have a label on it? Those labels heat up and gum up the mechanism.
    Or
    The unit is snafu. Look for the teeny tiny release spot.
    Jester243 and ManBeast like this.
  6. Aug 4, 2016 at 2:31 PM
    Tacoma Duluth
    Tacoma Duluth New Member
    2016 Tacoma TRD OffRoad
    Rokblokz Mud Flaps Painters canvas over the folded back seat for my dog
    I've had the same problem. Most of the time the CD ejects, but when it doesn't, I swipe a business card or a parking ramp ticket through the opening after pushing the eject button and while it is trying to eject. The CD usually pops right out.
  7. Aug 4, 2016 at 2:31 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    Sometimes when you disconnect the battery and reconnect, the radio then does not show a cd in the radio anymore. it happened to me once a long time ago. I ended up removing the radio from the dash and opening up the radio cover.
  8. Aug 4, 2016 at 2:34 PM
    ManBeast
    Zach
    Orange Park FL
    I took my entune out 2 weeks after i bought it and put a jvc i has laying around in. Hate the oem deck. Shitty sound and not loud enough . Jvc brought the oem speakers to life and made them far louder, with 20wrms vs the 2watts the entune was probably pumping out
  9. Aug 4, 2016 at 6:17 PM
    mthopton
    Thanks for the tips. It does try to eject, but only clicks. I tried the business card trick but not inserting needle nose pliers. The CD slot is so thin that there's no way to get pliers in there.
    I'll report back after a dealer visit tomorrow.
    Also, thanks for the tips on JVC. I have the OEM Audio+ system and it really woke up the system.
  10. Aug 4, 2016 at 7:38 PM
    imdav2u
    imdav2u Well-Known Member
    St. Louis
    2016 TRD Offroad DCSB 4X4
  11. Aug 4, 2016 at 7:46 PM
    Dudeman86
    Dudeman86 Well-Known Member
    Scottsdale, AZ
    2016 Black DCLB OR
    People still use CDs?
    Arailt and The hammer like this.
  12. Aug 4, 2016 at 7:57 PM
    Murrayb4
    Murrayb4 Internet Toyota Tech
    Downingtown, PA
    2017 Blazing Blue TRD Sport DCSB with 3 pedals
    Custom cracked windshield
    small pocket screwdriver is my preferred tool. digging around in there you'll find a small plastic piece that needs to be pressed up, and should then allow the CD to eject. this works 3/4 of the time.
    another effective method is "The Fonzie".. give the dash above the radio a nice firm hit with a closed fist, then try to eject again.
    as a toyota tech for 13 years, I joke that I have changed out more radios than I have changed oil....and every car comes in for an oil change.
    I'm starting to think its actually true.
    i've only seen two new tacoma's have stuck CD's, so far.
  13. Aug 4, 2016 at 10:06 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Try turning off the radio then restarting it. Worked for me.
    kgilly likes this.
  14. Aug 5, 2016 at 4:49 AM
    mthopton
    Thanks for the post. At the dealer now - we'll see what they come back with. I'm concerned that they'll take measures that could damage the internals or even scratch the face trying to get it out. What a PITA.
  15. Aug 5, 2016 at 4:50 AM
    mthopton
    Oh yeah, and CDs still have awesome sound quality. Much better than compressed music files or Pandora, XM, etc.
    smuckers, tomwil and Herniator like this.
  16. Aug 5, 2016 at 6:04 AM
    mthopton
    Update: The CD is out and supposedly the reason it was stuck is because it was a burned cd, so slightly thicker. Several normal CDs worked fine. Drama aborted!
    Kilokato, The hammer and Simon's Mom like this.
  17. Aug 5, 2016 at 8:29 AM
    tgear.shead
    tgear.shead Well-Known Member
    CDs are actually pretty low quality sound.
    16 bit per sample, 2-channel, 44.1 kHz. That makes 1,411,200 bits per second of uncompressed PCM audio, which is actually incredibly LOW compared to modern audio.
    They chose these specifications, because of the technical limitations of optical recording back in the 80's when this storage format was being developed.
    Essentially, they wanted the disk to actually be *compact*, yet be able to store a sufficiently long sequence of audio that it would be useful.
    So they ended up with 120 mm diameter disk capable of storing up to 1 hour 14 minutes of audio or roughly 640 MB.
    Keep in mind that back in the 80's, computer magnetic hard drives were only available in the range of 20-120 MB.
    Now modern technology allows everyone to store hundreds of *GIGA*bytes on a thumb drive that's smaller than a pencil. So CDs are pretty seriously obsolete now.
    If you look at a high quality *consumer* grade audio recording, you'll be looking at 24 to 32 bits per sample, 2 or more channels, 96 kHz. Or to put that into perspective, PCM audio streams of 6,144,000 bits per second or higher. On a 64 GB thumbdrive, you could store 174 minutes of this kind of audio.
    But we aren't done yet.
    Yes, audio that is compressed with a *lossy* compression algorithm can have a reduced audio quality, even though it decompresses back to 6 megabits per second. But there are better and worse compression algorithms, for instance, mp3 is a terrible compression algorithm that results in very flawed playback, it can be described as a metalic twang, or "robotic". Vorbis is a much better quality lossy compression algorithm that yields greater levels of compression at higher audio quality. Of course, you aren't limited to lossy compression algorithms. FLAC, for instance, can provide lossLESS audio compression. Now being lossless, FLAC files will be a lot bigger than those compressed with a lossy algorithm, but still a lot better than the raw PCM file. So you'd stretch out that 174 minutes to maybe 250.
  18. Aug 5, 2016 at 9:11 AM
    mthopton
    Uh...ok. thanks for that education.
    Kilokato likes this.
  19. Aug 6, 2016 at 9:01 AM
    Herniator
    Edmonton
    Does the radio in the Tacoma support FLAC?
  20. Aug 6, 2016 at 9:12 AM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    droppin knowledge! get outa here with that. 3rd gen section is all about silly responses and repeat threads
