stuck in 4 wheel drive- truck won’t move
Discussion in '3rd Gen. Tacomas (2016-2023)' started by alfonzo, Dec 23, 2017.
  1. Jan 8, 2024 at 3:57 PM
    #41
    Tailgate101
    Tailgate101 Member
    2018 Cement Tacaoma quad cab, TRD off road.
    I'm searching these forms trying to figure out why my 3rd gen manual is binding up. Luckily nothing this bad. But something is wrong.
  2. Jan 8, 2024 at 4:30 PM
    #42
    TacoVabes
    TacoVabes Well-Known Member
    22 DCSB SR5
    Yo are you alive??? Updates???
  3. Jan 9, 2024 at 5:31 AM
    #43
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Dude has 4 posts since 2017. He’s a ghost.
    usmc2msu, TACOTU3 and SR-71A like this.
  4. Jan 9, 2024 at 7:27 AM
    #44
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Describe what you mean by binding up, and under what conditions does it happen?
  5. Jan 9, 2024 at 7:45 AM
    #45
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Personal option the electric shift sucks, but if you don't use it that is the kind of stuff that happens. Even driving on a straight road switching it in and out of high range every so often helps. I push snow with my 2011, because I use low range to "push" snow instead of launch it I do exercise the high low system every so often year round.
  6. Apr 5, 2024 at 6:50 PM
    #46
    BDubbs13
    BDubbs13 Member
    bw
    Hello Everyone,
    Hopefully somewhere here can steer me in the right direction.
    Earlier today the family and I took our 2014 Trd Sport 4x4 off-roading in some mud and puddles. After the day was done we drove down to the local In-n-Out but when I was about to park I noticed my 4x4 lights were blinking and it was set on 2H. Well seconds later it felt like my truck was on a leash and I could no longer go forward as if my transmission was seized. I could only go backward or forward about 15 ft before it stopped me completely even ion neutral. The only way I could keep moving is if I turned my steering wheel in a different direction. I looked underneath the truck and I did not have any damage. Only think I found on the transfer case actuator was the vacuum hose had a small hole in it and was loosely on. I secured the hole with electrical tape for a quick fix and secured it with a zip tie but had no change in my trucks status. please let me know if you have felt with this before or know how to fix this. Thank you.
  7. Apr 5, 2024 at 8:58 PM
    #47
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Sounds like normal drivetrain bind up when in 4wd on a high traction surface. Get it out of 4wd and your issue will go away.
  8. Apr 6, 2024 at 3:35 AM
    #48
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Another fake thread maybe.
  9. Apr 6, 2024 at 4:08 AM
    #49
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    That hose is now vacuum, it’s a vent hose for the transfer case actuator. I would suggest changing that hose rather soon. Moisture and water intrusion into the transfer case actuator corrodes the electrical contacts. This will lead to not being able to engage or disengage four-wheel-drive
  10. Apr 6, 2024 at 6:07 PM
    #50
    BDubbs13
    BDubbs13 Member
    bw
    ****Update****
    Turns out my transfer case actuator had about a few sips of muddy water and the contacts for my 2H were shorted and melted down to the plastic surface. Fortunately my neighbor used to work as a mechanic and was able to
    Solder a new contact for me until the replacement part arrives tomorrow. The truck is now drivable and is now stuck in 2H with the 4wd and 4lo lights blinking in the dash. My neighbor said that might be due to the soldering or the need for calibration to the actuator.
    Chew likes this.
  11. Apr 6, 2024 at 6:19 PM
    #51
    jcat2435
    jcat2435 Active Member
    PNW
    2017 TRD Sport ACLB MT Quicksand
    OVTune 2.0 SFOB Premium + edits OV Catted Dump Tubes 4.88 gears F/R ARB Lockers 255/85 r16 Cooper ST Maxx Method 701 16x8" King 2.5 Mid Travel Dirt King Uniball Heimed UCAs Dirt King Uniball LCAs Deaver U402 stage 2 Hammer Hangers FJ Manual T-Case with twin sticks ADD Delete Core Shifter ADM RCI Skids + Sliders
    My experience with the actuator is that if it’s clocked incorrectly(small red encoder gear on cover) you’ll get the 4x4 change mode / abs failure pop up.
    Flashing 4/lo lights indicated to me that that the position switches on the cams (below the big gear) are not showing the truck the same shift position between t-case and diff actuators. Unfortunately I don’t have pictures but I believe 2hi is where both limit switches are disengaged but just about to get depressed by ramps on the cams.
