Stuck in 4hi 2018 Tacoma OR 4x4 DCSB
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 11Bravo4x4, Jul 8, 2018.
  1. Jul 8, 2018 at 11:24 AM
    11Bravo4x4
    11Bravo4x4 [OP] Well-Known Member
    Mitchell
    2018 Tacoma off road 4x4 quicksand
    Delete
  2. Jul 8, 2018 at 11:30 AM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    I don’t think rain makes a difference. Sometimes it’s better to not listen to Manuel, because things like this happen :p
    BlakeM, tn111, BSFord and 2 others like this.
  3. Jul 8, 2018 at 11:34 AM
    11Bravo4x4
    Mitchell
    I agree the rain shouldn’t have done this. The units are supposed to be sealed. But In a way I think IMO it’s good to thoroughly do a functions check on all new items to ensure reliability and proper function. So warranty can fix it before it expires and fix faulty items from factory.
    Joe23, TacoCon and synaps3 like this.
  4. Jul 8, 2018 at 11:42 AM
    synaps3
    synaps3 Wag more bark less
    Dave
    Los Alamos, NM
    2017 White SR5 4x4 DCLB
    SOS armor, ARE MX walk-in, Fox coils, Dakar leafs, etc
    No sense talking about it here. It's under warranty, so bring it to the dealer. They'll make it right.
    Sometimes the actuator gets stuck like you suggested. The manual specifically indicates you should regularly put it in 4hi to prevent this, so I'd start toggling it on every couple of weeks or so on a straightaway.
  5. Jul 8, 2018 at 11:45 AM
    Gary86
    Gary86 IG: 2a_Aviator
    Gary
    Corpus Christi, TX
    2018 DCSB Cement TRD 4X4
    I'm new to 4x4...so we should just place the truck in 4Hi every once in a while to keep things lubricated? And its ok to put it in 4Hi while driving? Thanks and excuse my ignorance on the subject.
  6. Jul 8, 2018 at 11:47 AM
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Good to exercise it every month, I think Toyota recommends 10 miles in 4hi but its pretty hard to do that without going out of your way to find forest service roads. Keep it offroad when you're in 4wd
    synaps3 likes this.
  7. Jul 8, 2018 at 11:47 AM
    TashcomerTexas
    Yes. Every other month or so will keep things lubricated and functioning. For 4hi it can be engaged up to 60 mph I believe. 4Lo should always be done while stopped.
  8. Jul 8, 2018 at 11:49 AM
    Gary86
    Gary
    Corpus Christi, TX
    Thanks guys. When I first got it about 3 weeks ago I placed it in both 4Hi/Lo to ensure everything was working. I'll set a reminder on my phone to do it at least once a month.
    synaps3 and rollin904[QUOTED] like this.
  9. Jul 8, 2018 at 11:55 AM
    synaps3
    Dave
    Los Alamos, NM
    Unless I go on a trip during the month, mine usually only gets ~2-3 miles a month tops. Anything is better than nothing!
  10. Jul 8, 2018 at 11:58 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Next time it gets stuck, try alternating between going in reverse, stopping in neutral, and going forward for at least 30 ft each way and repeat if its stuck in 4H or 4L, that helps.
    TacomaDaveB likes this.
  11. Jul 8, 2018 at 12:06 PM
    aleriance
    aleriance Well-Known Member
    Jorge
    Naples, FL
    2017 TRD Off-Road 4x4
    CMC 285/70/17
    You can engage/disengage 4HI while driving up to 60mph according to Toyota. You CAN drive at ANY speed once it IS ENGAGED.
    I have found that sometimes when switching on/off while the engine is accelerating/decelerating can cause engagement to be rough/loud so I've started making the habit of even if I'm moving, taking my foot off the gas for a second or two before switching in/out of 4HI just to be safe.
    As far as 4LO, the car will not let you go into 4LO until you are fully stopped and in either P or N, so it's not like you can really engage it on accident.
    4LO of course holds first and second gear pretty long so general rule is to not exceed 10mph or so while in 4LO.
    Gary86 likes this.
  12. Jul 8, 2018 at 12:13 PM
    toycoma 2016
    toycoma 2016 Well-Known Member
    jason
    Williamsport, TN
    2021 cement OR 4x4 dcsb
    Lots
    I had the same thing happen to me in my 16. Had to take cover off acctuator and pull solenoid shaft out of 4wd. Not a bad job on the trails but just a little annoying. Was able to get it replaced under warranty thought. They did have to pull the transfer case in my situation so keep that in mind too for yours. Good luck.
  13. Jul 8, 2018 at 12:18 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Bring back manual shift levers!
  14. Jul 8, 2018 at 12:18 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    When the indicator flashes the truck is detecting a condition that is not safe to make the shift change. This doesn’t mean it wasn’t stuck though. As stated above try slowing, stopping, backing or something different that traveling in the same direction at the same speed. These can be a little finicky and unfortunately it’s not perfect. Routinely excersising the actuator is absolutely recommended! I drive mine on paved surface without any issues- obviously not in 4L. I don’t make any sharp turns, don’t engage rear locker and don’t go above 35 mph when cycling mine.
  15. Jul 8, 2018 at 12:44 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    With shift on the fly there is a transfer case motor that must match the timing between the transfer case and transmission speed.
    It’s quite possible that the transfer case motor was struggling to match the speed. You can easily test this by switching into 4wd from a stop and rolling forward and also switch during acceleration and deceleration.
    MOC221_ likes this.
  16. Jul 8, 2018 at 12:47 PM
    11Bravo4x4
    Mitchell
    thanks for the comment. Was it the transfer case actuator... or the front diff actuator? I tried doing all of the above and no dice. Made a appointment for 0800 at the dealer.
  17. Jul 8, 2018 at 5:14 PM
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Landpirate, Stocklocker and MOC221_ like this.
  18. Jul 8, 2018 at 5:22 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    rock it back and forth from rev to drive fairly easy on DIRT when turning wheel back and forth. It can get in a bind and not release. My 14 has done the same. Engage dial to 4wd then try to go to 2wd.
    Other 4wds do the same. You do not need to just back 15 feet in reverse as some say since it isnt 1975 anymore.
  19. Jul 8, 2018 at 6:42 PM
    Friggin Fuego
    Friggin Fuego Well-Known Member
    2004 Toyota Land Cruiser, 2007 Toyota FJ Cruiser 6MT 4x4, 1988 Toyota Hilux SSR Diesel 5MT 4x4
    On my FJ, I usually gotta reverse making a left turn to get it out of 4 Hi. Sometimes these systems have a funny way of doing things.
  20. Jul 9, 2018 at 3:07 PM
    11Bravo4x4
    Mitchell
    So I went to the dealer and by the time I had got there the 4hi had disengaged and went back to 2hi. They could not replicate the problem and said it’s fine... I brought the truck home and 4x4 worked fine. It wouldn’t get stuck anymore. What a a coincidence
    I can’t help but to wonder maybe the rain had something to do with it since it was the FIRST time the truck has seen rain.. since day 1.... And now the (actutator) dried and fixed itself perhaps a hiccup?. But I thought these trucks were designed to be driven on harsh wet environments.
