stuck in Charleston WV, need rear gears
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by matthew5olson, Apr 12, 2011.
  1. Apr 12, 2011 at 2:18 PM
    matthew5olson
    matthew5olson [OP] Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    Need rear gears for elocker, don't care what ratio.
    A complete non locker axle is ok too.
  2. Apr 12, 2011 at 2:20 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    you on a road trip or something? bump!
  3. Apr 12, 2011 at 5:15 PM
    matthew5olson
    matthew
    pittsburgh, PA
    down here working. front dif went out on me then the rear followed
  4. Apr 12, 2011 at 6:10 PM
    matthew5olson
    matthew
    pittsburgh, PA
    anyone in the area
  5. Apr 18, 2011 at 4:02 PM
    Qlueless
    Qlueless Member
    Adam
    Centerville, In
    98 Taco Xtra-Cab v6 4x4
    If you are still looking, I might have what you need, and can ship?
    Check your PM's
