Stuck in deep snow... recipe?
Discussion in 'Off-Roading & Trails' started by mr2mki, Jan 14, 2015.
  1. Jan 14, 2015 at 5:36 PM
    mr2mki
    mr2mki [OP] Well-Known Member
    The other day I got up to my floorboards in snow, and had a hell of a time getting unstuck. I put on chains, put it in 4Lo and locked the rear diff, but I shut off ATRAC because it seemed to be screwing with me. I was able to apply power without much trouble, but my front tires weren't cutting the mustard so I couldn't steer, front tires would plow and truck would just run straight and wouldn't turn out of the rut my right side was in.
    I am now wondering in retrospect what I could have done extra.
    - Should I have left ATRAC on? Do people find it useful in loose deep snow on top of the locker?
    - Would airing down the tires have helped much?
    - I know you aren't supposed to put CHAINS on the front, but could I get a set of real skinny Z-cables or something like that?
    Also, more generally I should probably consider snow tires more seriously :D
  2. Jan 14, 2015 at 5:49 PM
    Qumodo
    Qumodo Kid Hauler Trail Rig
    Evan
    Colorado Springs
    2013 TRD Offroad
    Inno IN-SU roof rack
    you can run chains up front if you get 1.25" spacers.
  3. Jan 16, 2015 at 9:07 AM
    Louisd75
    Louisd75 Well-Known Member
    Northwest Washington
    '02 Xtra Cab, '15 DCSB
    Break out the shovel. Lots of times a few minutes with the shovel can make life much easier. Knock down the walls that are railroading you. A garden hoe will help a lot if you're up to your floorboards. It works much better than a shovel at getting snow out from under your rig (it usually just slides off the shovel). A nice long handled shovel and hoe will make life much nicer.
    Another trick I've used is the hi-lift with lift mate. Life a wheel up, fill in the hole with snow set the wheel back down. Doesn't take long to do each wheel, then you can back up and get another running start.
    Then of course, there's always the winch:
    19cbbc8d-ede2-425e-9856-c5e3a0548063_zps_0fdce95f00cf7523e5e2dcb17a84931077ddccd1.jpg
    DustStorm4x4 likes this.
  4. Jan 16, 2015 at 9:13 AM
    itsmemattp
    itsmemattp Well-Known Member
    Ashland, Oregon
    06 Tacoma Access Cab 4x4
    I really like the tip with the garden hoe, thanks! I would think airing down would have helped a bit...
  5. Jan 16, 2015 at 9:18 AM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    First step is to stop making your situation worse. AKA get off the skinny petal, step out of the truck and look at what is stopping you. I get stuck in snow a little to often and always find my way out.
    Soon as I stop moving I get out and grab my shovel. These shovels are worth it! I got a similar one for $20.
    Shovel a path that has little to no resistance. Make sure to have clearance for your diffs and anything else that can hold you up. If this doesn't work, then I air down to 10 or so PSI. Re clearance and try again. It may be a slow process but it works. You can also try to add traction by digging to dirt if possible and then sprinkling it in front of your tires. Tree branches can work sometimes but I never had much luck with em.
    The best purchase I have made is a pair of maxtrax. I lock the rear and put them both in the back. Then remove the snow from the front and I can get the truck out of the hole I dug myself in. Then its just a matter of being careful and taking my time so I don't sink to my frame again.
    Masshole_And_His_Taco likes this.
  6. Jan 16, 2015 at 9:18 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
  7. Jan 16, 2015 at 9:20 AM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    And when the winch jams...
    :anonymous:
    igno1tus and DustStorm4x4 like this.
  8. Jan 16, 2015 at 9:22 AM
    Manwithoutaplan
    ID
  9. Jan 16, 2015 at 9:23 AM
    geekhouse23
    That's Jon's next project..he's going to SAC it..
  10. Jan 16, 2015 at 9:23 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    It is just a button push, so not try it?
    It does make some serious weird noise in the front, but that is normal for A-TRAC.
    In snow, I enjoyed the combination of A-TRAC + the Rear Locker... in that mode, the A-TRAC remains off until you drop below 3 mph (almost stuck or stuck), then goes active for needed traction on the front. Without the locker on, A-TRAC works at all speeds in low range, but in snow with lots of slipping of the tires, there is a lot of grunting noise from the A-TRAC device.
    Not deep at all, but you can't expect too much snow here in San Diego!
  11. Jan 16, 2015 at 9:26 AM
    Manwithoutaplan
    ID
  12. Jan 16, 2015 at 9:35 AM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    alittle shoveling goes a long way. When I lived in Idaho you were always pulling people out of ditches and even then you had to dig out a path, otherwise you'd just drag them along the ditch instead of back up onto the road.
  13. Jan 16, 2015 at 9:40 AM
    Louisd75
    Ha! I had Jeverich with me, he's almost the Chuck Norris of snow travel
  14. Jan 19, 2015 at 11:31 AM
    mr2mki
    Thanks for all the great input! We definitely went to town with the earthworks, although we didn't have a hoe, that is a great idea. It was challenging because the "road" was packed snow/ice about a foot tall, and I had fallen off the "road" into the "shoulder" of loose snow. So we needed to ramp the right front up onto the "road", which was very challenging.
    SO we got:
    - Winch
    - Jack up, pile snow under wheel
    - Hoe
    - Air down
    Thanks again :)
  15. Jan 19, 2015 at 12:28 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Airing down helps with traction and flotation, but from my experience the best thing for snow is a good shovel. Might take some time, but you can almost always shovel yourself out.
  16. Jan 19, 2015 at 7:07 PM
    Thelgord
    Thelgord The Pantagonist
    Augusta, GA
    '13 TRD (OffRoad, 4x4)
    SOS Rocksliders, All Pro skid plate, Procomp add-a-leaf, Bilstein 5100 @ 1.75", CB, high-lift jack
    This is the one case where A-Trac is near useless. When one wheel spins, it stabs the break for that wheel forcing the other wheel to spin. In deep snow your A-Trac would have been going crazy and all of the noise it would have been creating can be off putting the first time you hear it. The problem is, if a wheel did have traction, the other wheel would have to break loose, stab the break, then send power to the wheel with traction, computer releases the break on the spinning wheel, wheel spins again, process repeats several times a second. In deep snow where you "may" have to keep applying power over distance is where I start to worry about damaging the front diff. A-Trac really is amazing, and I use it a lot when off road, but obstacles are often cleared in less than a minute. As a rule of thumb, the order I use is:
    1. 4W-Hi
    2. 4W-Hi + A-Trac
    3. 4Lo
    4. 4Low + A-Trac
    5. 4Low + Lockers (No A-Trac is needed with lockers on both ends)
    I will often skip "steps" if I can see a problem coming, and usually I can, but sometimes the mud is deeper or the rocks are more slippery than expected. I have also been considering the locker "any time" mod. My front locker is after market it is already "anytime".
    [Edited for clarity, typing while tired is bad :) ]
  17. Jan 19, 2015 at 7:19 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Why would you be in 4LO in that snow ?
  18. Jan 19, 2015 at 7:21 PM
    Thelgord
    Augusta, GA
    Look at the license plate ...
    brizower likes this.
  19. Jan 20, 2015 at 8:19 PM
    mr2mki
    In that guy's defense, I have been known to switch to 4LO when, thanks to whoops, 2nd is too fast and 1st is too slow, i.e. to get more gear choices under 20mph :)
  20. Jan 20, 2015 at 8:23 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Nice shovel, why the lighter?
