Stuck in fifth
Discussion in '1st Gen. Tacomas (1995-2004)' started by RicMor, Aug 29, 2023.
  1. Aug 29, 2023 at 4:12 AM
    RicMor
    RicMor [OP] New Member
    Ricky
    2004 Toyota Tacoma 4x4 extended cab manual transmission
    Flat Bed
    My 1st gen manual is stuck in fifth. Is there a way to get the truck out of gear without removing the tranny and taking it apart? The shifter bushing is like new. I have rocked the truck back and forth while jiggling the shifter until I’m blue.
    HondaGM likes this.
  2. Aug 29, 2023 at 4:29 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Welcome to the forum!!
    driving on hard surface with 4x4 engaged?? Severe torque bind can cause this to happen.
    How did this little mishap happen?
    Did you have any noise before this happened??
    5th gear is interesting .
    You can remove the shifter and move the linkage by hand if it is something minor
    HondaGM likes this.
  3. Aug 29, 2023 at 5:13 AM
    RicMor
    Ricky
    Flat Bed
    My 16 year old son did it. He said no noise or grinding or anything like that was heard. He stopped to make a turn and it was stuck.
    HondaGM likes this.
  4. Aug 29, 2023 at 10:45 AM
    Bivouac
    Best of luck getting this mess sorted out.
    HondaGM likes this.
  5. Aug 29, 2023 at 10:47 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW....He was Sending it?
  6. Aug 29, 2023 at 11:19 AM
    Bivouac
    Thinking about this I wonder if it is stuck between 2 gears .
    Just from lack of experience or just random bad luck.
  7. Aug 29, 2023 at 11:25 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Is the clutch disengaging when you press in the pedal?
    Bivouac likes this.
  8. Aug 29, 2023 at 12:44 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Did you try shifting the transfer case into neutral to make sure there is not load on the transmission? At the very least, that might allow you to push it off the road, if it's not already.
