Stuck In Park,,, WTF?
Discussion in 'Technical Chat' started by Tacomojo, Jul 8, 2008.
  1. Jul 8, 2008 at 2:23 PM
    Tacomojo
    Tacomojo [OP] Mojo Mofo
    Nashville, TN
    2019 TRD Pro, AT, White
    Out of the blue today I went to routinely shift out of Park to Drive and the shifter was stuck --- it would not move freely out of the gate! I literally had to beat the side of the shift lever to the right with my fist in an attempt to free the stuck shifter. Luckily, this did the trick and got me home, but I know something is obviously not right. As soon as the lever was moved back to Park, it became stuck again. :mad: Taking it to the dealer tomorrow A.M. (if I can again successfully beat the shift lever out of Park).
    It's a 2008 DoubleCab, Prerunner, 2WD, TRD Sport, w/V-6 and auto tranny.
    Has anyone else experienced this?
  2. Jul 8, 2008 at 2:25 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    not on my Tacoma. I had it happen on my parent's old Custom Cruiser. The switch that senses the brake lights went out and it wouldn't allow me to shift out of park because it thought my foot wasn't on the brake.
  3. Jul 8, 2008 at 2:27 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
  4. Jul 8, 2008 at 3:18 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    there is also a shifter lock under the lil black flap beside the P on the center console. might wanna see if something is messin w/ that...check the owners manual for proper procedure on it...its in there
  5. Jul 8, 2008 at 3:49 PM
    Charli
    Charli Stealer of Souls
    Chuck?
    Ohio
    '06 Black Sand 4X4 SR5 TRD Sport V6 Access Ca
    Towing pkg with Mossberg hitch cover, Toyota tube steps, 3" Toytec lift and TSB, 1" diff drop, Tacoma World sticker, sockmonkey decals
    Yup, had that brake light fuse blow on my old taco (2000). There is/was an override switch someplace, but I didn't know that at the time. I don't know if the new ones have the override, but the manual may have that as well--or maybe that's the switch hodge mentioned? I should probably look that up.
  6. Jul 8, 2008 at 5:37 PM
    Tacomojo
    Nashville, TN
    BINGO!!!
    Yep, checked the 10 amp tail light fuse under the hood and it was blown. Replaced it with the provided spare,,,, and it also blew when I hit the brake pedal. Hmmmm, all I can deduce is that (hope, hope) the wiring running from the left tail light to the A.R.E. topper's third brake light has gotten pinched (looked mashed) and is the source of the problem. Just disconnected the two wires near the splice connectors.
    Now, if the wife will just get her fanny home so I can run her car to the auto parts to pick up some fuses, we should be back in business [crossing fingers]!
    Thanks for the tip ----------- I hope to report success ASAP!!!
  7. Jul 8, 2008 at 5:53 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    woohoo! I helped! I can sleep easy tonight.
  8. Jul 8, 2008 at 6:44 PM
    Tacomojo
    Nashville, TN
    Yes,,,, You and Tacoma World helped in a big way!!! (Now, we can both sleep easy tonight,,, Hahaha!) Thank you so much!
    So, it WAS that pinched topper brake light wire. I didn't like the cheesy appearance of it when the topper was installed --- should have made it better back in March. Oh well. :(
    Hey, lsocoee, are you from the Ocoee area of Tennessee? We live just north of Nashville and plan to spend part of our summer vacation on the Ocoee River later this month. :D
    Dan
