Stuck in park
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Caddmannq, Feb 3, 2016.
  1. Feb 3, 2016 at 3:16 AM
    Caddmannq
    Caddmannq [OP] MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    Hey guys, my '09 tacoma gets stuck in park. This can happen when I start the engine, or put it in park while running.
    Sometimes if I pump the brake, it will shift, but sometimes I will shut it off and restart, an then it will shift.
    Sometimes the ABS light and stability control light will come on, then go off after a bit, or go off after using the brakes a few times, or stay on til I restart. This has happened about 6 times this month. It's been down to the 30 every night.
    I'm thinking a plug has got corroded somewhere & there's a low voltage on the ABS system, telling the computer the brake pressure is low.
    But that's just WAG.
    I have no Idea about the interlock system on this truck.
  2. Feb 3, 2016 at 3:28 AM
    0psi
    0psi Well-Known Member
    Tommy
    Westminster/glen burnie Maryland
    Color match handles,sport hood,fx-r retrofit,fog light any time,eclipse avn726e
    When it won't come out of park see if you have brake lights.it may be the brake light switch at the pedal.
  3. Feb 3, 2016 at 4:28 AM
    Caddmannq
    California
    Undercover toneau
    Stuck brake light switch?
    That would be easy to test.
    So obvious that I missed it.
    (I was still thinking of cables stretched or motor mounts sagging, as I fear the Toyota sagging motor mount syndrome.)
    Thank you 10x!
  4. Feb 3, 2016 at 5:07 AM
    0psi
    Tommy
    Post up what you find.
  5. Feb 3, 2016 at 5:23 AM
    chunt5
    chunt5 Senior Citizen Member
    chuck
    Cumming, Georgia
    2015 DCSB, Prerunner, SR5, 4.0
    When it is stuck in park, you can pop out the the little square plastic cover just above the "P" next to your gear shift. There is a button under the plastic cover that will allow you to shift out of Park if the brake switch is sticking.
  6. Feb 3, 2016 at 5:31 AM
    0psi
    Tommy
    Then he may be driving around with no brake lights.
  7. Feb 3, 2016 at 7:43 AM
    Caddmannq
    California
    Undercover toneau
    Exactly! :eek:
    They'd only be working part time.
    I also had a couple brief episodes where the brakes were very grabby at low speed. I didn't notice any dash lights when it happened.
  8. Feb 3, 2016 at 8:53 AM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    Definitely check your brake lights.
    On my Honda Ridgeline I installed a back up camera. In the process I mixed up some wires and popped the fuse for the brake lights. The truck would start up and show no indicators of a problem but was stuck in P. quite a while I discovered the simple mistake and it was a easy fix. Since it is intermittent for you, my guess is the switch at the brake peddle.
  9. Feb 3, 2016 at 11:14 AM
    Caddmannq
    California
    Undercover toneau
    I played with the switch a bit, cleaned the fuzz off of it, made sure it was plugged in and working.
    The brake lights work OK, but we'll see what happens to them the next time it sticks.
    For $35 I'll just pick up a spare on the way home, but for today, no problems so far.
  10. Feb 3, 2016 at 11:36 AM
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    Pretty sure your fix is none of the above. My shifter did this when i got my truck. Additionally it popped out of drive and into neutral when driving (scares the shit outta you haha). I had to lube a shifting mechanism on the side of the tranny under the truck. Follow the shift cable from the cab and youll see what im talking about. If i recall right, it was triangular in shape and has contacts on one side that when you move the shifter, connects the contacts appropriately to shift the truck. I hit it with some wd-40 and 1.5 years later everything is perfect.
    Let us know what happens
  11. Feb 3, 2016 at 3:38 PM
    Caddmannq
    California
    Undercover toneau
    I think that's the neutral safety switch.
    Mine has never popped out of gear. Never heard of an automatic doing that.
  12. Feb 5, 2016 at 10:26 PM
    Caddmannq
    California
    Undercover toneau
    Well I did 2 things guys. I tightened the battery cables and cleaned the brake switch and the problems are gone.
    I may have had a slight low voltage condition or some such, plus a lazy switch.
    But, the brakes were grabby at times. I'm not sure why that happened but it's gone too.
  13. Feb 14, 2016 at 6:45 PM
    lilgerber
    lilgerber Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    I'm having the same problem, I have to it the button above "P" to get into gear, and the brakes seem to be grabby at times.
    I'll go clean the brake switch, but i thought it was my brake booster failing, I have a 2006 TRD off-road if that matters.
  14. Feb 15, 2016 at 2:08 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The brake switch is more often the cause for not being able to shift out of park.
    The grabby brakes are a separate issue which has nothing to do with the switch.
  15. Mar 1, 2016 at 12:15 PM
    Caddmannq
    California
    Undercover toneau
    I changed that switch. It took about 30 seconds once I got down there.
    Twist, pull, unsnap, snap, push, twist, done!
