Stuck in snow, advice needed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kadenm, Jan 16, 2022.
  1. Jan 16, 2022 at 11:22 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
  2. Jan 16, 2022 at 11:25 PM
    averagejp
    averagejp Well-Known Member
    2005 Black Tacoma Extended Cab
    Work in progress
    This is a great forum ... OP, thanks for posting this ... and I am glad you are safe!
    As a north easterner (who loves California), I am afraid my experience can't help much. As someone earlier said, California snow is just different. My concern would be how deep is the snow and what is underneath. In the North East, our ground gets pretty frozen solid so you can sink and then get traction when you get to hard ground, assuming the snow is not too deep. But I am not sure what the ground condition is under all that snow. Sometimes, we get lucky and the snow is wet and compacts tight enough that you can get some traction.
    A few solid suggestions here, such as have plenty of warm clothing, supplies and emergency gear. And, of course, shovels. Real shovels like the one posted earlier. Those cute Overland shovels really don't do a lot when you have that much snow. Definitely get some chains but not the fancy modern ones (nothing wrong with those in the right conditions). But the old school chains with big teeth. The bigger and uglier the better!
    I would add to the sound advice you have been getting about walking ahead and avoiding the snow drifts. I find it very helpful to have a snow marker in the truck for these purposes. That way I can poke the snow and get a sense as to how deep it actually is -- and how far it is until I hit ground. That won't help if the ground underneath is a mushy mess but good to know.
    Side note: I have a nutty cousin who lives way north in Quebec. Loves to play in the snow. Dude actually tosses one of those electric snowblowers in the back of his truck and clears the path that way. Of course, his buddy thinks he is nuts and just loads a snow mobile in the back ... he is never one to be unprepared. I kid you not.
    But really look forward to the other thoughts here so I can learn a bit about the difference in the snow at Mammoth ... I would like to get out there one day.
  3. Jan 16, 2022 at 11:38 PM
    orangeracer
    orangeracer Well-Known Member
    18' DCSB TRD OR 4x4 w/6spd MT
    I did some snow wheeling this month too and learned how easy it was to get stuck. Big snow rated tires with clearance really does help but even guys out there with 37s still got stuck. We ended up airing down to 12psi and it really helped more then I expected, we just kept speeds down nice and slow. As mentioned above, always carry an emergency overnight snow kit, warm clothing, blankets/food/water/extra fuel etc.
    Beside that, I learned what worked best is not just one thing but multiple, low psi, chains, lockers and a winch. All in conjunction with a buddy vehicle or two equipped with the same items. Cool pics though and glad you guys got out, fun stories to remember.
    Kadenm[OP] and averagejp like this.
  4. Jan 16, 2022 at 11:53 PM
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    A winch would’ve probably been your best friend in this scenario, at least to get you back onto your tracks from before you got high centered, then find a spot to turn around and follow them out. Keep your rear locker and MTS on (which simulates a front locker) in the deep stuff. If you get chains, make sure they clear your UCAs and fenders when your suspension compresses, otherwise they’ll chew things up. And the bigger the tires, the less room for chains you’ll have. Besides the standard self recovery gear, Always keep extra water, food and blankets!!! in the truck when you’re in the snow, in case you don’t get unstuck. My dad ran a business called “Mountain Towing” when I was growing up, and I went on more snow recoveries with him than I can count. I have seen a lot of hypothermic people almost freeze to death because they weren’t properly prepared.
  5. Jan 16, 2022 at 11:53 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    This one is a grain shovel. It isn't super wide but it is shaped in such a way that it'll move a lot of snow, quickly. I was very glad I had it that second time I high-centered myself in the snow.
    tcjacado, DingleTower and averagejp like this.
  6. Jan 16, 2022 at 11:55 PM
    averagejp
    Work in progress
    Good point on the chains -- and making sure they fit. I would add to that, be sure to lace your chains up and test them before you need them. Not as easy as you think to get them on your truck when you have never done it before, it is cold and you are in deep snow.
    Sound advice here ... thanks !
    Kadenm[OP] and RedWings44 like this.
  7. Jan 16, 2022 at 11:56 PM
    RyanDCLB
    4/19 DCLBOR
    I'd say, experience is superhelpful. Go around and play in the snow. Momentum is key, keep your tires spinning. Spin your tires at a high revolution to eject the snow from the treads. If you come into a fresh line, hit reverse super quick and back up into your previous tracks. Never stop in a fresh snow bank. Air down before you hit the snow, like 12-15 psi. A front Locker will help a lot. My best traction while in thick snow was with Yokohama mud tires. Always travel with a buddy and don't enter anything unless you're confident that you can get out. Fully locked, mud tires, snow chains, shovels, gloves, headlamp, second vehicle, the ability to stay the night, recovery gear, food and water. Spin it to win it! (while in motion)
  8. Jan 17, 2022 at 12:10 AM
    jgrider16
    jgrider16 Active Member
    CO
    2020 DCSB MT. Quicksand. Has some extra goodies.
    Bilstein 5100 lift. SCS Ray10 w/ 33". Toyo RT. RSI SPORTCAP. Stinky children on Carhartt seat covers. Heated cloth seats (Unicorn option?)
    I have the same one on my deck. It'll move more snow in an hour than I can ;)
    RedWings44[QUOTED] likes this.
  9. Jan 17, 2022 at 12:23 AM
    092trfe4x45sp
    092trfe4x45sp Active Member
    Grew up in Alaska. Mud terrain or more aggressive at 10 psi on trails and drop as low as 6 if it’s over the axles or to get un stuck. I wouldn’t drive fast or corner aggressively at 6 but it really helps if you plowing a path.
    FastEddy59 likes this.
  10. Jan 17, 2022 at 12:49 AM
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    Winter clothing would be a good start.
  11. Jan 17, 2022 at 6:04 AM
    woods_24
    woods_24 Well-Known Member
    2009 Black TRD Sport DCLB
    Flip flops and a hoodie???
  12. Jan 17, 2022 at 6:04 AM
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    from the looks of their age. id say call mom.. one dude has flip flops on and they all just have sweat pants on..
    you know if there was no one else up there and you guys died because you froze and didn't have the right gear, your moms would sue Toyota for the tacoma getting stuck and then tacomas would be banned in California.. because California..
    and then the world would be safer?
  13. Jan 17, 2022 at 6:26 AM
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    Yes, I was wondering the same thing. Very millennial. At least get a pair of warm socks and boots it you're going to be going out in the snow.
  14. Jan 17, 2022 at 6:58 AM
    Inferno!
    Inferno! Well-Known Member
    El Dorado Hills
    2018 TRD OR Inferno 285/65/17
    Supercharger, sway bars, lift, leather, tires, Gobi, etc.
    I got stuck in the snow and used crawl control for the fist time. It worked! That and as someone said experience.
    averagejp likes this.
  15. Jan 17, 2022 at 7:16 AM
    #35
    Admiral_Akbar
    Admiral_Akbar Well-Known Member
    '17
    TRD Bro’s get stuck tho (no hood scoop).
  16. Jan 17, 2022 at 7:16 AM
    #36
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    If you're High centered with your truck sitting on the frame / skid plate nothing much you can do besides having some pull you out with a snatch strap . If you can use a shovel and remove as much snow as you can from under your truck and a few feet from the tires in ea direction . Next lower your air pressure to 12 psi then with steady throttle control try and back out as reverse uses lower gearing
    straightawaykid and FastEddy59 like this.
  17. Jan 17, 2022 at 7:26 AM
    #37
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    Nokian LT3 in 285/70R17 or 315/70R17.
  18. Jan 17, 2022 at 7:36 AM
    #38
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Find someone else to go out there with you in another vehicle. A come along is fairly inexpensive and getting the vehicle to move a foot or two is usually all it takes to get going again. "I'm only going a couple miles out there." Out here in the desert I come across too many people stuck out there with no water etc. I always carry water and some good hiking boots or shoes. The cell phone doesn't always work out there so alway's have a plan to hike out. Water, gear etc. Let someone know where you are going and around when you plan on returning. Oh, and let them know if you run into some friends and your plan's change... don't ask me how I know that.
    willie2 and averagejp like this.
  19. Jan 17, 2022 at 7:38 AM
    #39
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I've been in similar situation powder on top ice below powder. I had to use crawl control and some digging and I got out
    Kadenm[QUOTED][OP] likes this.
  20. Jan 17, 2022 at 7:40 AM
    #40
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Be the forth one in line.
