Stuck in the snow- out. Not a call for help
Discussion in 'New Members' started by ShhDisturber, Jan 15, 2017.
  1. Jan 15, 2017 at 12:50 PM
    ShhDisturber
    ShhDisturber [OP] New Member
    2012 toyota tacoma 4x4
    Time to get some yet winter snow tires hard packed snow and I got stuck for an hour any ideas?20170114_093145.jpg
    mattgecko likes this.
  2. Jan 15, 2017 at 12:51 PM
    Caliph420
    Caliph420 Well-Known Member
    Washington
    2012 SR5 2.7 AC 4x4 Manual
    upload_2017-1-15_12-51-49.jpg or [​IMG] I keep both on me at all times + chains
    mattgecko, ODNAREM and neverstuck like this.
  3. Jan 15, 2017 at 12:54 PM
    DrFunker
    DrFunker Well-Known Member
    Are you still stuck?
    Yeah, snow tires would be good.
    Weight in the back?
    Chains?
    Some kind of traction? Sand, good for bed weight too.
    edit: yeah, shovel ^^^^
  4. Jan 15, 2017 at 12:56 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    All of this, also.... for deep snow, airing down can help substantially.
    Tacofart and DrFunker[QUOTED] like this.
  5. Jan 15, 2017 at 1:07 PM
    DrFunker
  6. Jan 15, 2017 at 3:15 PM
    ShhDisturber
    No I got out but that the belt around the tire idea is a fantastic one yeah we shovel ourselves out took about an hour probably less Aluminum shovels no doubt
    Never bought chains... Easy to put on?
  7. Jan 15, 2017 at 3:41 PM
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    What is the name of that strap? I want to pick up a couple for gifts.
  8. Jan 15, 2017 at 3:42 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    Updated your title.
    ShhDisturber[OP] and ODNAREM like this.
  9. Jan 15, 2017 at 4:16 PM
    Caliph420
    Washington
    Trac grabber https://www.tracgrabber.com/
  10. Jan 15, 2017 at 4:17 PM
    Caliph420
    Washington
  11. Jan 15, 2017 at 4:29 PM
    Caliph420
    Washington
    I keep chains in my bed cabinets too, but once your dug in and stuck its hard to put chains on properly. Thats where the trac grabber comes in handy to minimize digging time
  12. Jan 15, 2017 at 5:13 PM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
  13. Jan 17, 2017 at 7:19 AM
    Pigpen
    Dan
    Northwest Montana
    More aggressive tires, especially true snow tires will help immensely. Even good tires don't get you far in really deep, dense snow without airing down. I usually go straight to 15 psi. Experiment with driving around the neighborhood to see how low you can comfortably air down with your particular setup. While experimenting, run something over (like a stick of firewood or similar size object) to see how much squish you get - you don't want to damage a wheel playing in the snow.
    I've driven home a long way at 20 psi on stock size tires and it felt safe enough, though a little "loose". I have an air compressor now (highly recommended), so going lower is no longer an issue.
