Stuck in trailer assist mode? No trailer to hook up and fix it? Here’s my solution!
Discussion in '4th Gen. Tacomas (2024+)' started by evlfred, Jan 4, 2025.
  1. Jan 4, 2025 at 5:59 PM
    evlfred
    evlfred [OP] Member
    24 Limited iMax
    I towed my snow blower to get it serviced with my buddies utility trailer (4 pin) and my truck got the infamous “stuck in trailer assist mode” issue ever since. Tried all kinds of things and the dealer was two weeks out to try the TSB which they said my truck didn’t even qualify for (?!). So I ordered one of these 7 pin emulators off Amazon.
    https://www.amazon.com/dp/B004BCA9B8
    Plugged it in and it detected a trailer (made it “horse” cause I’ll never have a horse) and drove up the road with the emulator attached. Stopped with it running, Unplugged the emulator then drove a little ways and stopped. Got the trailer disconnected message and selected yes. Bam!!! All better!
    Almost blew a gasket on the next stop when the light came back on but it was just snow on the back sensors whew.
    You are all welcome!!
    hojo., timmers, Go636 and 5 others like this.
  2. Jan 6, 2025 at 7:45 PM
    SchwarzeEwigkt
    SchwarzeEwigkt Well-Known Member
    Central NY
    ‘24 Tacoma TRD Sport 4x4, Solar Octane
    Seems to me that they could solve this problem by adding a button to the interface that says “No, I don’t have trailer connected, ffs!” The button would then set it to whatever state it needs to be in so it doesn’t act like the trailer is there.
    Lawfarin and batacoma like this.
  3. Jan 7, 2025 at 7:02 AM
    mattm55
    mattm55 Well-Known Member
    Mid-Hudson Valley, NY
    2017 BBPearl Tacoma TRD Sport Access/AT w/SnoWay
    But what about the "horse". :rofl:
    Thanks for the tip.
    Go636 likes this.
  4. Jan 7, 2025 at 7:42 AM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    Don't know about the OP, but I couldn't stop myself from trying every type of trailer-type selection they included to see if it made any difference.
    Do they have a "U.S.A. Military Tank" selection as a choice? :D
  5. Jan 7, 2025 at 8:50 AM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    As you may know, when you disconnect (with the truck off) and start up again, it asks if the trailer is connected, and you have to give it the proper response–by pushing the button–and it shuts off. I've towed a dozen times and never had an issue.
  6. Jan 7, 2025 at 9:17 AM
    SchwarzeEwigkt
    Central NY
    I seem to recall that the questions it asks and the responses it requires are kind of counterintuitive. What I'm suggesting is a blanket "shut it off" button.
  7. Jan 7, 2025 at 12:34 PM
    PEAKIT
    PEAKIT Well-Known Member
    UT
    24 Off Road long bed Premium Taco.
    OME 888 nitro front, SPC upper arms,B110 rear shocks, Timberen bump stops, extended brake hoses, U bolt flip, sway bar delete, Dakar HD leaf pack with extra leaf, Snug top HD shell, MobTown Skid plate, cooper Maxx 255-85-16 4:88 Nitro gears,Spider trax 1.5 spacers, AirBedz, debadge, Pro grill.
    Whats even more fun is if you just have to move a trailer from in front of your house to your driveway and don’t hook the harness on. It will slam the e brake on over and over and refuse to back up. Sometimes it does this in my garage.
  8. Jan 7, 2025 at 12:49 PM
    Lennyz1
    Lennyz1 Well-Known Member
    Len
    2024 TRD Sport Premium Hybrid 4x4 Bronze Oxide
    I towed my trailer this weekend and now the same thing. It will not disconnect! WTF!!
  9. Jan 7, 2025 at 1:05 PM
    john877
    john877 Well-Known Member
    2024 Tacoma TRD Sport
    Have you tried turning off BSM and RCTA? Which is basically what the trailer detected mode does.
    PEAKIT[QUOTED] likes this.
  10. Jan 7, 2025 at 2:50 PM
    PEAKIT
    UT
    Yea I have its off. It still comes on erratically. Maybe it can actually be turned off in techstream .
  11. Jan 7, 2025 at 4:51 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Hope you get this sorted out. I would like to avoid this feature on any 4G I might drive. I won't be doing much if any towing and wouldn't need it anyway.
    I wouldn't mind just the brake controller. I don't know what this trailer assit feature is bundled with. The only option for the Prerunner is a pkg that includes the brake controller and parking sensor. I'd give up the controller to lose the parking sensors.
  12. Jan 9, 2025 at 6:46 AM
    chasea1989
    chasea1989 Member
    Chase
    Las Vegas, NV
    2024 Tacoma SR5
    timmers and dneal like this.
