Stuck in trailer mode
Discussion in '4th Gen. Tacomas (2024+)' started by Jrzydvl, Apr 11, 2024.
  1. Jun 30, 2024 at 2:01 PM
    #141
    Brentbba
    Brentbba Well-Known Member
    Tacoma Trailhunter
    I've got one of these. Will give that a try! No trailer tho, just a 2 bike rack!
  2. Jun 30, 2024 at 2:07 PM
    #142
    Korywithak
    Korywithak Well-Known Member
    Central Pa
    2024 TRD Sport Premium in Windchill
    It works off the sensors or the truck from what I was told. Not the actual trailer hook up so a bike rack would make sense. It would also make sense why it would ask about a bike rack. In this case you would push no.
    Want-a-taco likes this.
  3. Jun 30, 2024 at 2:21 PM
    #143
    Brentbba
    Tacoma Trailhunter
    Yep, first two times I answered No and all was good. Went to do the same and accidently pressed ok with the answer at yes. My error, but removed the rack and went for a couple of short drives. That didn't work, so I'll try my 7 pin to 4 pin adapter without a trailer and see if I can't fool the tech!
    Want-a-taco[QUOTED] likes this.
  4. Jun 30, 2024 at 8:36 PM
    #144
    Brentbba
    Tacoma Trailhunter
    Well, drove the truck a little longer this evening to pick up some sushi. Started the truck to come home and had the choice on trailer detected so I very carefully this time said NO and all is good.
    PDKTaco likes this.
  5. Jul 1, 2024 at 10:01 AM
    #145
    Jrzydvl
    Jrzydvl [OP] Well-Known Member
    2024 Tacoma SR5
    Stuck again and when I'm towing a small trailer with a box on the front while backing up out of no where the truck slams on the brakes,,, not cool! WTF.
  6. Jul 1, 2024 at 10:07 AM
    #146
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    Try a sushi run.
  7. Jul 1, 2024 at 10:44 AM
    #147
    Want-a-taco
    Want-a-taco Well-Known Member
    New Brunswick, Canada
    2024 TRD Offroad 6MT black
    Smells fishy.
    Sagebrush[QUOTED] likes this.
  8. Jul 1, 2024 at 10:49 AM
    #148
    trey_is_a_jedi
    trey_is_a_jedi Active Member
    From my experience with using hitch accessories the truck does better at detecting things when you do some full lock turns in forward and reverse. With my hitch carriers I select 'no' for trailer but I go into vehicle settings and disable parking brake assist so I can actually back up. Its annoying that a warning comes up in my messages constantly but whatever.
    Brentbba[QUOTED] likes this.
  9. Jul 1, 2024 at 1:12 PM
    #149
    Brentbba
    Tacoma Trailhunter
    I've got the parking brake assist off too!!!
  10. Jul 1, 2024 at 1:13 PM
    #150
    Brentbba
    Tacoma Trailhunter
    Absolutely!!!
  11. Jul 5, 2024 at 8:40 AM
    #151
    Highfield
    Highfield New Member
    2024 TRD Sport+
    I had the same issue - I was backing boat trailer into a lake. Didn’t bother with the seven pin connector as it was only 40’ from where I hooked onto trailer. Trailer assist detected trailer, from backup camera or blind spot sensor and put truck in trailer assist mode. Unhooked trailer later but trailer assist stayed on. I’m thinking I missed a question about if trailer detached/attached so it stays on until the next time you hook up to a trailer. Fix for me was to hook back up to trailer, pulled ahead 6 ft, put it into reverse. Then question popped up “detected a trailer”. Picked “no” but make sure to hold ok button in for at least 10 seconds. Then trailer assist went away. Backed trailer up to its original spot and unhooked. Problem solved but honestly, do I really need an automatic trailer detection system - no. I should just be able to turn system on manually and shut it off manually.
    TOMRR and SR-71A like this.
  12. Jul 5, 2024 at 8:58 AM
    #152
    Want-a-taco
    It should work like on my 2015 GMC, if a trailer is plugged and it detects it, it’s on, if not it’s off. There’s option to override if driving with tailgate open or something behind not connected.
  13. Jul 15, 2024 at 6:47 PM
    #153
    JakeSouliere
    JakeSouliere Active Member
    2022 Red Tacoma Sport Prem
    All stock.
    Thanks for the useless tip.
    Here’s the answer: it’s a bug. A bad design flaw that needs a software upgrade.
    CrispyTacoLover likes this.
  14. Jul 16, 2024 at 5:19 AM
    #154
    Want-a-taco
    Yes, it's a bug or bad design or both.
    JakeSouliere[QUOTED] likes this.
  15. Jul 20, 2024 at 1:40 PM
    #155
    Harleytacos24
    Harleytacos24 New Member
    2024 Tacoma
    None yet
    ***Update ***
    There is a sequence of steps to follow to unhitch a trailer, and to show your truck to not detect it. I believe it’s a built in safety feature so everything is disconnected before you drive off.
    But what i had to do was hook up a trailer, plug in the 7 prong and drive around at about 25 mph. Once my truck detected a trailer i hit Confirm. I then parked my truck, turned it completely off and unhitched the trailer and unplugged the wires.
    Then i drove away until my truck asked to confirm there was no trailer detected. I hit Yes, no trailer detected and the message went away and all my safety features returned to normal. Hope this helps.
  16. Jul 21, 2024 at 6:16 AM
    #156
    Jrzydvl
    2024 Tacoma SR5
    We all need to hound the Sh_t out of Toyota to fix the Bug. Having to go through this amount of bull.... is ridiculous. The idea is neat but un-necessary for anyone that pulls a trailer more than once a year.
    I think the 7 pin connector needs something attached to power pins to help system reset. I am attempting to rig a 7pin conn. so I can just plug it in and the system shuts off.
  17. Jul 21, 2024 at 9:28 AM
    #157
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    I wouldn’t count on an update until the 2025’s ship.
  18. Jul 21, 2024 at 10:28 AM
    #158
    Sagebrush
    Gens 1, 2, 3, and 4
    When an owner brings their vehicle to a dealer for a warranty issue, Toyota knows about it. Warranty repairs are expensive for the company, so when they detect an issue, they change the vehicle.
    Notice the shutter issues went away? Their chief engineer mentioned an acronym for a group that monitors new-roll-out models–and of course, I can't recall it. In the same video, he mentioned a software upgrade that will happen in August for the one broken front-end issue.
  19. Jul 21, 2024 at 10:36 AM
    #159
    Want-a-taco
    It would be a pain, but we should all go to the dealer to get them to remove trailer mode after unhooking.
    JakeSouliere likes this.
  20. Jul 21, 2024 at 10:38 AM
    #160
    Sagebrush
    Gens 1, 2, 3, and 4
    I think that would require rewriting the software.
