Stuck/Locked in Park
Discussion in '1st Gen. Tacomas (1995-2004)' started by slim pickens, Apr 26, 2010.
  1. Apr 26, 2010 at 9:12 PM
    slim pickens
    slim pickens [OP] Active Member
    Dear Taco Community - Currently own a 2001 Tacoma XCab SR5 4wd Automatic 2.7. Was raining when I hooked up my trailer today to pick up a rear tractor blade and run some errands. Last stopped at Giant and When I went to leave it started up nicely but the shift selector is now Locked in park and my Toyota is stuck at Giant :confused:.
    What/where would be the first step to troubleshoot this problem? Is there any manual release that this 2001 Tacoma would have to unlock the Shift Selector? Thank you for taking the time to help this senior citizen. SP
    charlie230 likes this.
  2. Apr 26, 2010 at 9:14 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
    There may be a small access panel on the shifter trim that you can pop open and push the button beneath it. That will most likely work.
  3. Apr 26, 2010 at 11:19 PM
    slim pickens
    Thank you! Will check that out and see if I can find any. SP
  4. Apr 26, 2010 at 11:33 PM
    gfor2048
    gfor2048 New Member
    Davie,Florida
    07 Prerunner TRD Sport SR5
    First post, 07 TRD Sport SR5 Pre-runner Crew cab. Just had the same problem, was at Dealership for 12 days. Check fuse in engine compartment (IG 10AMP), This problem is from your trailor lights. You have a bad ground on one of your lights, the 12v current is traveling back through the harness and blowing the fuse. Fix your trailor lights, this should fix the problem for sure.
  5. Apr 26, 2010 at 11:35 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    His is a 2001. It may not be the same problem as yours.
  6. Apr 27, 2010 at 2:04 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Like said above, should be a release button. And check your fuses. I have read and experienced this and saw this happened to a older 4runner also that a fuse blew locking the shifter in park. That would be were I would start.
  7. Apr 27, 2010 at 5:51 AM
    Barnone
    Barnone Guest
    One of my trailers had a short in the wiring and blew the tail light fuse on my 2002. It was locked in park like the OP's. Called the service shop and they told me about the slot iby the shifter. Replaced the fuse and fixed the wiring on the traile and was good to go.
  8. Apr 27, 2010 at 7:49 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Ha...stuck in park...I drive stick.
    But seriously, I believe it is the trailer light fuse as a couple people have said, but even if it isn't, the truck should have a shift lock release button. My family's Civic has one that requires the key to operate, so if it happened to that car I would use it to get the car into neutral (still starts in N) and then move to drive from there.
  9. Apr 27, 2010 at 8:13 AM
    REDSEAWATACO57
    REDSEAWATACO57 Active Member
    Chanh
    seattle,wa
    19 Toyota Tacoma Dbl cab TRD
    Modded
    It is possible your "brake switch" is out. Try a couple of things. Rest your hand on top of the shift lever and depress the brake peda, you should feel slight twich in the lever or you could here the shift lever unlock. If you depress the pedal and don't hear anything most likely the switch is out.
    the switch is located above the brake pedal, climb under and look upward along the metal of the brake pedal and you should see it. press in the pedal and listen for unclicking sound. No sound mean bad switch.
    You could buy these at any autopart store. Hope this helps..
  10. Apr 27, 2010 at 8:18 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    that worked for me when i had the same problem, I had a blown fuse that caused the problem
  11. Apr 27, 2010 at 8:26 AM
    slim pickens
    NC Gazzer and LarryJ like this.
  12. Oct 4, 2016 at 5:25 PM
    RawsonB
    RawsonB New Member
    2007 Silver Tacoma PreRunner
    Had this on my 2007 as an intermittent problem. Dealer fond a bad brake switch component which was covered by a 150,000 mile warranty! Replaced free!
  13. Mar 23, 2024 at 4:03 AM
    CamboTim
    CamboTim New Member
    I have the shifter lock in park intermittently in my 2006 Tacoma V6 4WD. I know when it's going to happen when I turn the key on and the lights on both the ac button and the air intake button do not go on. the fan still works. What could be causing this?
    stuckprerunner likes this.
  14. Sep 3, 2024 at 12:44 PM
    stuckprerunner
    stuckprerunner Member
    2008 Silver Tacoma Pre-runner
    I have the same issue any luck?
  15. Sep 3, 2024 at 9:05 PM
    foresterfields40
    foresterfields40 Well-Known Member
    ‘99 Tacoma 3.4 4x4
    Might pose your question in the 2nd gen thread
  16. Sep 27, 2024 at 8:18 AM
    stuckprerunner
    Update: Found the issue on my 2008 double cab 2wd pre runner. The rear harness connecting to the tail lights (since I don’t have tow harness) was rubbing on the rear part of the frame and finally broke through the protective covering causing it to ground out. Therefore blowing the IG1 fuse and locking it in park.
