Stuck! Middle of a leaf job. Need help.
Discussion in 'Suspension' started by 96Taco, Jul 23, 2011.
  1. Jul 23, 2011 at 6:05 PM
    96Taco
    96Taco [OP] Well-Known Member
    Alberta
    2014 DBL CAB Tacoma
    I have replaced my leaf on the driver side. Im installing the pack back in but cannot get the center bolt to sit in the hole on the axle top.
    I have already bolted in the shackle and leaf and also the opposite side long bolt to the leaf. I just cannot get that damn center bolt to sit in the middle axle hole. Tried lifting and lowering axel..
    Does anyone have any suggestions or tips how they did there's?
    Just have to play with it or what?
    thanks
  2. Jul 23, 2011 at 7:29 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    pics would help alot. the center pin too big to fit in the hole?
  3. Jul 23, 2011 at 7:36 PM
    jmayday23
    jmayday23 Well-Known Member
    Joel
    North Carolina
    '10 4WD TRD Sport DCLB
    Grillecraft, Hella 500 HIDs, weathertech mats, yellow fogs, OME 885's with shocks and AAL. Bridgestone Revos 285/70-17
    I just did mine last week, had to jack the axle up so the leaf pack was sitting on it and I just wiggled it to get it to seat. Once it went in it stayed, so just try a little muscle and hopefully it will find its way.
  4. Jul 23, 2011 at 8:14 PM
    BulletToothTony
    BulletToothTony TTC #0001 Im only a dick 90% of the time
    You can call me Susan if it makes you happy.
    Need some pics, I had to kick it to get it into place.....
  5. Jul 23, 2011 at 9:15 PM
    96Taco
    Alberta
    2014 DBL CAB Tacoma
    Thanks guys.. Muscle was the answer. Ended up calling my neighbor over. One was using legs to push on it HARD while the other wiggles it for that pin to fall in to the hole.
    Learning curve. But happy with days work.
  6. Jul 23, 2011 at 9:17 PM
    tacomalex
    tacomalex Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    when I did mine I used a hammer more than a wrench or a ratchet in the rear. not to mention I broke one of my ratchets too.. (that was taking the leaf pack off though)
  7. Jul 25, 2011 at 12:04 PM
    96Taco
    Alberta
    2014 DBL CAB Tacoma
    Yup she's pretty tight back there!
    I accidentally cross threaded the bolt on to my shackle. Spend at lease an hour rebuilding the thread. Whoops.
