Stuck oil dipstick
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DakoTaco, May 20, 2018.
  1. May 20, 2018 at 12:53 PM
    DakoTaco
    DakoTaco [OP] Well-Known Member
    North Coast
    2016 MGM OR Tacoma
    Avid front bumper guard OVtune HPS Intake Tube Meso designs counting
    Okay, I've searched thru the forum & only found the jokes about stuck dipsticks. I cannot get the stick out of there, twisting, pulling, whatever, it won't pull free. I gave it as much effort as possible without pulling the handle off. Anybody else have this happen and even more importantly, if you did, what was the fix? Thanks
  2. May 20, 2018 at 12:54 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Ok, I hope this doesn't come across as me insulting your intelligence, but are you sure you're pulling on the dipstick? Post a pic of it.
    hiPSI, ORtoCOTaco, zoo truck and 4 others like this.
  3. May 20, 2018 at 12:56 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Happened to someone else. Dealership got it free, IIRC.
    OnHartung'sRoad likes this.
  4. May 20, 2018 at 1:01 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Who put it in last? If you, was it hard to put in? Short of cutting the top off and opening the oil pan and pulling in the opposite direction from the bottom, it may need some mechanical assistance to pull up, but I would let the dealer do it as you might break it off or something else deeper in the channel.
    shakerhood likes this.
  5. May 20, 2018 at 1:03 PM
    Loco38SUP
    Loco38SUP Well-Known Member
    North Seattle, WA
    2011 Double Cab SR5 4X4
    Loud as hell URD exhaust!
    Mine did the same, I was able to work it loose by twisting it back and forth. The o-ring was shredded afterwards. Now I use o-ring grease on it at every oil change.
    -RJM
    muskratX22 and ChadsPride like this.
  6. May 20, 2018 at 1:08 PM
    OnHartung'sRoad
    I know its thick metal, but you know what happens to metal when you twist or bend it a lot. I wonder if theres a slight bend in the channel? If so, there’s a sweet spot that the stick has to bend to go back in and if the stick is sideways to it it cant make the bend easily and will twist to do it. Try to keep the stick oriented the same way when you find the best spot whenever its put in.
  7. May 20, 2018 at 1:37 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Happened to 1short or whatever, you just gotta pull. Extremely hard.
    hiPSI and T4RFTMFW like this.
  8. May 20, 2018 at 3:31 PM
    DakoTaco
    North Coast
    2016 MGM OR Tacoma
    It was the dealership on my last free lof, hopefully they checked anyways
    I'll twist it a little more & see if I can get it free, and use o-ring grease on it if it frees up
    Crazy, are they afraid it's going to leak or what?
  9. May 20, 2018 at 3:35 PM
    stun gun
    Aaronski
    Tacomas.
    No, Larry in procurement got the specs wrong, now we all suffer.
    rtzx9r and T4RFTMFW like this.
  10. May 20, 2018 at 3:35 PM
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
  11. May 20, 2018 at 3:50 PM
    DakoTaco
    North Coast
    2016 MGM OR Tacoma
    LMAO!
    Got the dang thing free finally, put a socket extension thru the handle so I could get better leverage, pulled & twisted, about fell backwards when it finally let loose. Thanks @Loco38SUP, used o-ring grease on it.
    P. S. Oil level was OK. :)
    tonered, Norsemanvike, hiPSI and 3 others like this.
  12. May 20, 2018 at 3:57 PM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Happened on my 09, I traded it before it got fixed. But it was to the dealership that did all my oil changes and they knew it was stuck, but were going to charge me to fix it. They told me about it the last 3 oil changes.
  13. Apr 15, 2021 at 4:59 AM
    Fooburger
    Fooburger Well-Known Member
    Jim
    Southampton, PA
    2011 Tacoma sr5 access cab
    3” w/jba’s. LCE header w/intake spacer & hps cai tube
    Omg, mine is so stuck in there. Sprayed it and used extension, and still stuck.
    Going to let it sit a bit see if grease loosens it up.
    Bleep100 likes this.
  14. Apr 15, 2021 at 6:16 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Long Live StunGun :drunk:
  15. Apr 15, 2021 at 6:21 AM
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    Work a flathead screw driver under the bottom lip of the dipstick handle and the tube and pry it up. And order a new dip stick.
    SR-71A likes this.
  16. Apr 15, 2021 at 6:33 AM
    Fooburger
    Jim
    Southampton, PA
    Wow, finaly got it. Grease, step ladder, extension and alot of muscle....
    wilcam47 and Loco38SUP like this.
  17. Apr 15, 2021 at 6:38 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Next time I pull my dipstick imma throw a new oring on it and use some red rubber grease. @Fooburger if u get a new oring let us know what size u get.
    Loco38SUP and 71tattooguy like this.
  18. Apr 19, 2021 at 8:44 AM
    Loco38SUP
    North Seattle, WA
    That’s what I do now as normal maintenance. Once its stuck its a Mother F to get out.
    -RJM
    Skydvrr[QUOTED] likes this.
  19. Apr 19, 2021 at 9:00 AM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    One of the best tips I got from this forum is filing the sharp edges on the tip down with 300 or 400 grit. Made putting it back in (giggidy) much easier. Make sure to give it a good rinse in brake cleaner after doing that to get the metal powder off.
    HP11, Kev250R and Thatbassguy like this.
  20. Apr 19, 2021 at 9:27 AM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    When you pull it does the truck fart? if so, it may not be a dipstick.
    Woodini likes this.
