Stuck Oil Filter on 4.0L...Godzilla works for Toyota!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RKCRUZA, Jan 13, 2016.
  1. Jan 14, 2016 at 2:26 AM
    billybob50
    billybob50 Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
    As to why it's so hard to come off. I believe the engine when it's assemble at the factory it's cold, and the rubber gasket was lube. Now after a few thousand miles the gasket material has fused itself to the metal surface because of the oil on the gasket has dissipated, and the medal filter has expanded against the engine block. I've always use only two fingers and my thumb, so I don't over tighten the new oil filter. That oil wrench is great, but I've had problems with the spring tensioner popping off. Ended up putting some caulk adhesive around the spring clip to keep it in place. Do like to put in about 8 to 12 ounces of oil in the filter, so it's not dry when I startup the motor for the first time.
  2. Jan 14, 2016 at 2:51 AM
    devkurf
    devkurf Member at Large
    midwest
    I use my belt. The last change, the wife had to keep tension on the belt while I broke it free by hand. It really snugs down for whatever reason.
  3. Jan 14, 2016 at 6:01 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    12 oil changes on my 2009, all by me. Only the first was a problem - since then filter removal/install is by hand, no tools required. My theory is oil filter gasket was NOT lubed when engine was built. Also guess engine is built in one plant, shipped to a separate plant for vehicle assembly, and engine doesn't get ANY fluids until the truck rolls off the production line.
    Old School likes this.
  4. Jan 14, 2016 at 6:05 AM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    I change mine by hand...
  5. Jan 14, 2016 at 6:06 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    My filter is a bitch every time. Had to use a rubber strap wrench last oil change. And I only ever hand tighten when I change my oil with OEM filters.
    My crush washer for the oil drain plug also seems to have fused to the oil pan lol.
  6. Jan 14, 2016 at 6:07 AM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
  7. Jan 14, 2016 at 6:24 AM
    billybob50
    Bob
    The only reason you lube the oil filter gasket. Is to keep you from getting a false feeling of the filter being prematurely tight. The manufacturer when assembling engines ether apply pressure to the oil ports or prerun the oil pump to lube the internal parts. http://www.autoserviceprofessional....ing-a-critical-procedure-for-any-fresh-engine
  8. Jan 14, 2016 at 6:26 AM
    TacoTaco15
    TacoTaco15 Well-Known Member
    Jake
    VA
    2015 MGM DCSB PreRunner 2.7
    I have a feeling this is somehow going to warp into a 'best oil' thread... :spy:
    12TRDTacoma likes this.
  9. Jan 14, 2016 at 6:37 AM
    billybob50
    Bob
    TacoTaco15[QUOTED] likes this.
  10. Jan 14, 2016 at 6:43 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    I get mine tight by hand when I change the oil, but when I go to take it off 6000 miles later I use these to get it off:
  11. Jan 14, 2016 at 6:52 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
  12. Jan 14, 2016 at 6:56 AM
    Chrome Beer
    Chrome Beer 7th Ceaser
    Dave
    Florida
    15 DCSB SR5 4X4
    Thank god i got toyota care for the first 25k on my 15. I used to dread getting the filter off my 06. They put it an angle so almost impossible to get a grip on. Then no matter what filter i used if you tried going 5k+ miles on synthetic good luck getting it off. I will be getting one of these filter sockets right away i'm not looking forward to this again.By the way when i bought my 15 i asked about changing the filter in a 16. The guy said its even more of a pain.
  13. Jan 14, 2016 at 7:13 AM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    Hey @DoorDing, where can I buy one of those?
    I have a Cambodian Tire, HH, and Car Quest in my town. Everything else is 30 minutes away in Belleville.
  14. Jan 14, 2016 at 7:22 AM
    billybob50
    Bob
    I tried that route, ended up crushing the oil casing. Then tried it with a oil chain wrench, it was messy and had very little room to work in. That Lisle 63600 oil filter wrench is the way to go, along with an oil drain valve!
  15. Jan 14, 2016 at 7:26 AM
    #35
    TacomaMike37
    13' DCLB MGM
    Amazon
  16. Jan 14, 2016 at 7:26 AM
    #36
    billybob50
    Bob
  17. Jan 14, 2016 at 7:26 AM
    #37
    TacoTaco15
    Jake
    VA
    I found mine at my local auto parts store.
  18. Jan 14, 2016 at 7:35 AM
    #38
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
  19. Jan 14, 2016 at 7:36 AM
    #39
    ppfd
    ppfd Well-Known Member
    WV
    09 TRD ext. cab 6 spd
    I've got a whole collection of filter removal devices.
    Best one I found for tacoma filters is a cap filter wrench, 73 mm, 14 flutes. Advanced auto or any auto store has a rack of various sizes.
    Fits a little snug, I use a short extension, and zip it right off.
    I am going to have to add one of those lisles to the collection now though. :D
  20. Jan 14, 2016 at 8:38 AM
    #40
    LunaticConcepts
    LunaticConcepts Well-Known Member
    Georgetown, TX
    2015 Tacoma TSS
    TC LT, Kings, OME, Billies, ARB, stuff
    I crawled in my bay, and used a mouse pad to grip the filter with lol
