Stuck Oil Filter on 4.0L...Godzilla works for Toyota!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RKCRUZA, Jan 13, 2016.
  1. Jan 15, 2016 at 4:56 AM
    #61
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    It come out of the box dry. You have to lube it before installation.
  2. Jan 15, 2016 at 4:58 AM
    #62
    murderedtaco23
    murderedtaco23 Well-Known Member
    Jesse
    Campton NH
    09 dbl cab trd sport
    OME 3 inch lift all the way around, 285 75 16s, fog light any time, HID, Rock sliders, 30 inch bumbper LED, LED pod ditch lights
    may be mentioned already, but ive heard rumors the gaskets are not lubed at the factory
  3. Jan 15, 2016 at 5:04 AM
    #63
    thewarriordinghy
    thewarriordinghy General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    All this talk, but does Godzilla work at Toyota? Still looking for him....
  4. Jan 15, 2016 at 5:10 AM
    #64
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    I meant factory installation. For the record I work at Subaru,and we manufacture the Camry as well. Every once in awhile someone will get on the intercom and play a recording of Godzillas roar,it's hilarious!
  5. Jan 15, 2016 at 5:25 AM
    #65
    Lester Lugnut
  6. Jan 15, 2016 at 5:26 AM
    #66
    Monkeybutt2000
    Yes it does.
  7. Jan 15, 2016 at 5:54 AM
    #67
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    I find the oil change routine on the 4.0 truly easy. Good placement of filter, little drain hole for overflow. Easy access drain plug with stock skid plates on. I like changing the oil on this truck more than any other vehicle I've owned. Proper filter tool for removal of first filter from factory helps.
    sixspeedlife likes this.
  8. Jan 15, 2016 at 6:45 AM
    #68
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Same here but did my first change at 1500.
