Stuck on trail need help!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jimmy 123, Sep 16, 2017.
  1. Sep 16, 2017 at 11:22 PM
    Jimmy 123
    Jimmy 123 [OP] Active Member
    i have a 2016 Tacoma 4 wheel drive. This is what is wrong-
    Out of nowhere, the truck started turning to the right. No pop or anything. When we cut the wheel when it's jacked up the tire spins only on the drivers side. Maybe something with the steering rack? Inner and outer tie rods are intact and tight, working as they should. What's wrong???
  2. Sep 16, 2017 at 11:28 PM
    mateo_roberto
    mateo_roberto Well-Known Member
    Mateo
    San Diego, CA
    1995.5 Tijuana Teal 4x4
    Stock
    Can you give a better description of the problem? Sounds like the front right tire is jammed up when it's off the ground & spun by hand?
  3. Sep 16, 2017 at 11:31 PM
    Jimmy 123
    When jacked up and cutting the steering wheel, it's goes left to right along with the tire and cvs spinning at the same pace as the wheel turning. It's dark now, wish I had taken pics
  4. Sep 16, 2017 at 11:34 PM
    Jimmy 123
    While driving straight it pulls sharply to the right
  5. Sep 16, 2017 at 11:35 PM
    mateo_roberto
    Mateo
    San Diego, CA
    Stock
    Take some pics if you can. Possible you bumped your alignment out of wack?
    9TRDTCO and DrFunker like this.
  6. Sep 16, 2017 at 11:40 PM
    Paul123
    Paul123 Web-Wheeler
    Paul
    Reno
    2014 TRDOR pyrite mica, 3" lift 33's, 4.56’s
    Or severely bent the tie rod. Op I doubt the steering rack is the problem. Any weird noises?
  7. Sep 16, 2017 at 11:46 PM
    tcjacado
    tcjacado Well-Known Member
    Where are you at? What trail?
    Btw welcome to TW!
  8. Sep 17, 2017 at 1:03 AM
    Sammie
    Sammie :D :P ;)
    NC
    ‘17 Tacoma BBP
    Is it possible the brakes have seized on that side?
  9. Sep 17, 2017 at 1:09 AM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    See if you get GPS coordinates. People on this site have been rescued by members willing to help out. But they have to find you first.
  10. Sep 17, 2017 at 1:19 AM
    Toyo_newb
    Toyo_newb Well-Known Member
    Matthew
    2017 DCLB TRD OR 4x4 QUICKSAND
    This is my first use of this one, but this thread seems worthy.
    :popcorn:
  11. Sep 17, 2017 at 1:26 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    That was my 1st thought as well. A collapsed break line will act like a check valve, not allowing the caliper to release the pressure on the pistons. If this was the case, there would likely be a brake dash light lit up-especially on a '16.
    Fortunt1, Jeffhrb8 and Sammie[QUOTED] like this.
  12. Sep 17, 2017 at 4:29 AM
    dsixnero
    dsixnero Well-Known Member
    Dan
    2016 Tacoma TRD Off Road White
    None yet
    OK, so your right front wheel is stuck, are you in 4x4 or crawl control? if so, go back to 2wd and see if that solves the problem. If your not using the 4x4 then it's probably a stuck brake, call the dealer,have them pick you up.
  13. Sep 17, 2017 at 5:45 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    A broken CV joint on the left side would cause a pull to the right under acceleration....but only in 4 wheel drive
    El Duderino and scottalot like this.
  14. Sep 17, 2017 at 5:48 AM
    Clearwater Bill
    Billy
    Largo Florida
    A dealer is going to retrieve from a trail?
    My 50 cents say no.
  15. Sep 17, 2017 at 6:12 AM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
  16. Sep 17, 2017 at 6:16 AM
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    2012 Blue Tacoma 4x4 Pre-Runner
    4x4 Conversion w/ FJ T-Case, King 2.5 Extended Travel Coilovers w/ JBA UCAs, King 12" 2.0 Smoothies w/ BAMF relocate in the rear, OME Dakar leaf pack, 4.56 gears w/ ARB air locker, Archive Hammer Hangers w/ crossbar brace, ARB Snorkel, Custom Bed cap w/ Roofnest Sparrow XL, Retrofit Headlights, Wrapped in 3M Satin Perfect Blue
  17. Sep 17, 2017 at 6:21 AM
    neegra
    neegra Well-Known Member
    GA
    2016 DCSBTRDOR4x4
    I think OP is trying to say that when they lift the truck and turn the steering wheel, only the driver's side moves with the input?
  18. Sep 17, 2017 at 6:38 AM
    Livetoohunt
    Livetoohunt Member
    TRD Pro Tacoma
    None
    I had a broke axle (cv axle)give me the same result on my 2nd gen 8 years ago. But as mentioned only would do this in 4 wheel
  19. Sep 17, 2017 at 6:40 AM
    Livetoohunt
    Livetoohunt Member
    TRD Pro Tacoma
    None
    But I knew it because when it broke it popped sounding like a shotgun went off
  20. Sep 17, 2017 at 12:51 PM
    Toyo_newb
    Matthew
    Hope you made it out ok OP, let us know how it turns out.
    El Duderino likes this.
