Stuck open thermostat.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ares32, Feb 22, 2018.
  1. Feb 22, 2018 at 5:50 PM
    Opihi59
    Opihi59 Vulgar Boatman
    Beyond Honolulu
    2016 TRD Sport DCSB 6MT
    Unknown lift, maybe 2" I don't know how to ID it, and would rather set it back to stock.
    These plastic things get very fragile after 8-10 years, the small caliber hose connections simply snap off. I've tried to repair with threaded barb fittings and they don't last. I've replaced numerous of these on Ford Focuses, VW Jettas, and others that I simply cannot remember. Generally though they are cheap and in the $12-$20 range though often they have to be special ordered.
    That already problematic plastic water pipe on the back of the engine of the 3.5 is going to become a real issue in about 10 years, if it isn't already, and if the thermostat is not replaceable without replacing that entire plastic housing.......well, whomever came up with that as an acceptable design should simply be tied upside down to a pole after being force-fed exlax.
    over60 and Ares32[OP] like this.
  2. Feb 22, 2018 at 6:07 PM
    Ares32
    Ares32 [OP] Well-Known Member
    America
    2016 MGM TRD off road DCSB M/T
    Haha! Yeah I'm used to replacing the simple thermostat itself. God damn toyota screwed us by integrating the thermostat with the housing. Just your typical money grab SMFH....
  3. Feb 22, 2018 at 6:16 PM
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    The engine doesn't create much heat at idle. Next time this happens...pop the hood and feel the upper radiator hose. If warm, your tstat is bad. If cold,it's just that your engine isn't creating enough heat when cold.
  4. Dec 4, 2018 at 7:29 AM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    OP, when this happened to you did you get a CEL at all?
    I had a similar experience this morning when dropping off a friend at the hospital for a surgery. It was 15 degrees outside. Noticed that even after driving for 20 minutes the temp needle was just barely over the 1/4 mark. Stopped at a light after driving for 30 minutes, sat at light for 2 minutes, and when I drove away from the light the temp needle quickly dropped to the quarter mark. Took roughly 3/4 miles of driving before it returned up to the halfway point.
    Did you have any luck with the dealership? Was your thermostat indeed busted?
    Thanks!
    Ares32[QUOTED][OP] likes this.
  5. Dec 4, 2018 at 12:45 PM
    Jh8473
    Jh8473 Well-Known Member
    Bowling Green
    2025 Tundra SR5
    None
    What was the outcome?
    Ares32[OP] likes this.
  6. Dec 6, 2018 at 10:07 AM
    Ares32
    America
    Sorry guys but I traded my Taco in for a Tundra.....haha
