Stuck rear shock nut
Discussion in 'Suspension' started by DPC08, Mar 15, 2020.
  1. Mar 15, 2020 at 9:30 PM
    DPC08
    DPC08 [OP] Well-Known Member
    FL
    09 DCSB
    Getting there...
    Hi everyone. Currently trying to replace my Icon 2.0 shocks on the rear of my 2nd gen Taco. The top nut is stuck. When I lock the shock body from spinning, it looks like the whole bolt assembly itself is trying to unscrew itself from the shock body. Any tips on how to keep the bolt from spinning off the body? My next step is to try using heat on the nut, but I'm wary with it being so close to the bed. Thanks in advance
  2. Mar 15, 2020 at 9:32 PM
    Thuguon2.7
    Thuguon2.7 Cheeehuuu
    J
    SoCal.
    ‘15 1GRFESR5AC
  3. Mar 15, 2020 at 10:22 PM
    GOLIVER0131
    GOLIVER0131 TrdMo
    Socal
    '17 Wht Trd OR DCLB(TrdMo)
    TrdPro grille, blackout badges. Pretty much stock.
    I would start with a rust penetrator. If you don't mind marring the shock shaft you can use a pipe wrench to try and hold the shaft still. Otherwise go to a shop and have them remove it. They'll have shock shaft jaws to keep the shaft from spinning. But since you're removing the shock you're prob not going to put it back on so you can always cut it off.
    Fox 2.0 w/no res, go to a shop and they'll replace it for $30 after buying the replacement.
  4. Mar 16, 2020 at 6:27 AM
    DPC08
    FL
    09 DCSB
    Getting there...
    Thanks so far. It's been sitting in liquid wrench/PB Blaster the past few days. It's not the shaft itself that's spinning, rather the mounting bolt that screws onto the shock body. Not enough room to get grips on it. I'm going to try to get a nut splitter next
  5. Mar 16, 2020 at 9:59 AM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    There "should" be flats on the stem top to keep it from spinning. If not cut it off above the frame and you can install a new stem from Icon.
  6. Mar 16, 2020 at 12:47 PM
    tacomarin
    tacomarin ig: @travelswithchubbs
    Bay Area
    2018 DCLB TRD OR
    Prinsu Cab and Top Rack VO Drifter LED Interior, License Plate, and Reverse Lights Huskyliner Weather Beater floor mats Salex Center Console Organizers 35% Front/15% Rear Tint Debadged and De-stickered Anytime Front and Rear Cameras Brute force front bumper BAMF HC Dual swing out 285/75r17 BFG KO2 Front: ADS 2.5, EXT, RR, Clickers Rear: OME Dakar HD, ADS 2.5, EXT, RR, Clickers Stainless steel brake lines (+4 in rear) Wheeler's Offroad Superbumps Front and Rear Wheeler's Offroad U-bolt flip ECGS CV Axle Bushing SCS Stealth 6 17x8.5 wheels, matte dark bronze
    No sure about Icons, but some have an allen key hole on top of the stud.
  7. Mar 16, 2020 at 12:59 PM
    MattiveAmerican
    MattiveAmerican Well-Known Member
    2006 White ACLB
    BuiLt 4 OveRLanDiNg
    ^^^^what he said. OR call icon and ask if it even matters if that stud comes out. If it doesn’t matter if you unthread the stud, which it probably doesn’t, just unthread it and order new stud and buy from icon. They’re awesome with replacement parts and can get you anything you need
  8. Mar 16, 2020 at 2:28 PM
    Georgia Native
    Georgia Native Well-Known Member
    4x4 DCLB 2017 SR5, 2019 4runner Offroad, 2021 SR Access Cab
  9. Mar 28, 2020 at 5:37 PM
    UOFan
    UOFan Well-Known Member
    Bryan
    NC
    1994 Single Cab DLX, 2013 TRD Sport, 1999 Dodge 2500 360 V8
    5100 Lift + AAL
    OP this is exactly what I used. Bang it out with a rubber mallet once complete. Good luck! :sawzall:
  10. Nov 2, 2020 at 2:18 PM
    crhsharks12
    crhsharks12 Well-Known Member
    Denver, CO
    ‘06 Tacoma 4WD TRD Sport DCSB 4.0L V6
    RR 2.5 King shocks front/rear, Camburg UCA's, Icon AAL Springs Softopper & BA Bumper
    Hey OP
    what did you end up doing?
  11. Nov 2, 2020 at 2:19 PM
    crhsharks12
    Denver, CO
    Ended up experience the same issue RIGHT now as I type this. The bolt stem on the top part of the shock is removing itself from the shock body. Meanwhile, that stem removing itself is causing the nut to have zero torque on it, and is therefore not loosening :/
  12. Jan 17, 2022 at 5:09 PM
    jonger
    jonger New Member
    What I do when this happens is pull the wheel, take a grinder and grind two flat opposing faces into the rod so I can put a wrench on the rod to keep it from spinning.
    Takes about a minute to grind the rod flat and the nut comes right off once you can get a wrench on the rod.
