Stuck Rotor, ideas?
Discussion in 'Technical Chat' started by logcabinwc, May 11, 2014.
  1. May 11, 2014 at 3:55 PM
    logcabinwc
    logcabinwc [OP] Well-Known Member
    Micah
    SF East Bay
    08 4d 4x4 White V6 TRD
    Old Man Emu 885s with Nitrocharged 90000, Bilstein 5100 in the back with AllPro 3 spring progressive AAL, 16 inch Baja Black 6-spoke alloy wheels, Flow Master exhaust, bed lights, Pioneer HD radio, Uniden CB Radio, K&N Air filter, BAMF Sliders w/kickout, Relentless Aluminum IFS Skid, 24 LED light bar, custom/homebuilt expedition style bed rack and basket combo, and Body Armor rear plate bumper.
    Short of going at it with a blow torch and heating up the rotor, anyone have any ideas to get off a stuck rotor? or any words of caution on what not to do? I finally gave up today and put everything back on (replacing both rotors and pads) I had enough after 3.5 hours of hitting the damn thing with penetration oil and banging on it with a damn hammer. I just could not get the driver side rotor off.
    Any advice would be greatly appreciated. I'll be seeing my parents next week and I'm going to borrow my dad's "burzomatic 4000" torch. If that doesn't work I don't know what the heck I'm going to do.
  2. May 11, 2014 at 3:57 PM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    Did you put bolts in the threaded holes?
  3. May 11, 2014 at 3:58 PM
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Are there holes in the rotor you could thread a couple bolts into to press it off the hub? Haven't looked at my tacos brakes yet but that's a fairly common feature.
  4. May 11, 2014 at 3:59 PM
    avw4x4
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Beat me to it :D
  5. May 11, 2014 at 4:03 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    PB BLASTER works very well. better than most penetrating fluids.
  6. May 11, 2014 at 4:32 PM
    logcabinwc
    Micah
    SF East Bay
    Shit.
    No. Damn it. I'm even more mad at myself now. Granted this is the first time I've done this but I should have looked closer and realized what those holes were for.
    Ok, well since you guys know more about what we're talking about do you know what size bolt fits in there?
  7. May 11, 2014 at 4:33 PM
    avw4x4
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Probably a 12mm. Pop the hood and grab one and see if it fits
  8. May 11, 2014 at 4:39 PM
    logcabinwc
    Micah
    SF East Bay
    Ok, I'll try this after work tomorrow. Have too much other stuff to do today, Thanks for you help though, hopefully I can crank this out tomorrow
  9. May 11, 2014 at 4:42 PM
    avw4x4
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Good luck man, hope it works out for you!
  10. May 11, 2014 at 4:43 PM
    SoutheastTaco
    steven
    columbia sc
    09 trd sport dc 4x4
    Haha.. We all derp out sometimes!
  11. May 11, 2014 at 4:47 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  12. May 11, 2014 at 10:46 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    The bolts I use to remove a stuck rear drum are M8-1.25 . I'd start there.
  13. May 11, 2014 at 11:16 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    The bolt holes to pop my brake drums off fit the bolts that held the skid pan on.
  14. May 12, 2014 at 7:00 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Same bolts, if it's a stock rotor.
  15. May 12, 2014 at 7:09 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    bolt holes stripped on my rotors when i did them. hammer wouldn't knock them off, so i just swung the blunt side of an ax at the back of the rotors. two taps and they came right off. only use this method if you are replacing the rotors though, because you'll dent the rotor.
  16. May 12, 2014 at 12:28 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    FYI: Most axes are heat treated, and will snap when struck with another hard object, or vice versa. Hope yours hasn't. Hate to see you mess up an axe when sledges are cheaper;)
  17. May 12, 2014 at 12:45 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i wasn't full swinging with it. that was 3 years ago. same axe still lives in the bed and is going strong to this day.
  18. May 12, 2014 at 1:55 PM
    logcabinwc
    Micah
    SF East Bay
    Yep I have new slotted rotors going on. Just makes me nervous because if I beat the hell out of the rotor and still cant get it off, I'll have to drive the truck to a shop so they can do their magic..
    I'll try the bolts tomorrow after work, and if that doesn't work I'll move onto the Burnzomatic 4000 and a hammer to the back of it.
  19. May 12, 2014 at 2:01 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    either buffer the rotor with a 2x4, or use a composit dead blow hammer if you're worried abotu marring the rotor and still having to drive. even a small ball peen hammer will dent the rotor
  20. May 12, 2014 at 2:05 PM
    avw4x4
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    My trusty 3lb HF hammer has yet to let me down on jobs like that. If the screws don't work I would just wail on it :D
