Stuck Skid Plate Bolts
Discussion in '1st Gen. Tacomas (1995-2004)' started by SaltSlasher, Jun 2, 2014.
  1. Jun 2, 2014 at 11:51 PM
    SaltSlasher
    SaltSlasher [OP] Member
    Utah
    04' Tacoma Reg. Cab 4x4
    Factory Upgrade Package's: -Alloy Split Star 5 Spoke -P265/70R16 Tires -Overfender -Hood Protector Add On's: -Black License Plate Cover -Heavy Duty Floor Mats
    I was going to do some work following some DIY's I found, and one of them was radiator flush. So I decided to pull the plates off to do my fluids.
    I literally broke an old ratchet trying to remove the two front bolts on the front skid plate. I put some WD-40, and lube, and then tried with my combination wrench with the circle end getting the tightest grip possible and I am still incapable of removing the bolts. I removed all the other bolts and have the tranny plate out, so I know I am not doing it wrong, and I am also missing the middle bolt for the front, so I can see the nut is welded on top, and that they should remove like the others.
    I am turning the wrench counter clock wise. I try slow power pull, and have tried more powerfull yanks, including with a hammer.
    In my DIY's, they just say "remove the skid plates", and then don't cover the removal of them, like it is suppose to be a breeze, like "pop the hood". Even the few places I found about it, didn't mention them being hard to remove, they just showed where they are at.
    I guess I want to know if they are different, like if there is a technique for removing them? Because they feel like they are welded on, and I feel stupid for doing doing one of the most basic of jobs and getting stuck on the first step.
  2. Jun 3, 2014 at 12:00 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Need more leverage and a 6 point socket.
    No they're not welded, just rusty.
  3. Jun 3, 2014 at 1:25 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Mix ATF/Acetone 50/50, spray on and let it work. Repeat a few times. And get some leverage. Cheater pipe, combo wrench linked to the first one, or best option would be a breaker bar and six point socket. Patience!
  4. Jun 3, 2014 at 5:43 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    How old was that ratchet you broke, I've always broken the bolt before breaking a ratchet. If you are still unsuccessful then I would say "grind, drill, rethread".
  5. Jun 3, 2014 at 5:58 AM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Pb blaster over night sometimes helps. I have a 30" piece of pipe that I use for breaker bar. Slide over ratchet handle for leverage. 6 pt socket for sure. Sometimes heat will help also. GL
  6. Jun 3, 2014 at 10:24 AM
    Moco
    Moco Well-Known Member
    Eric
    NoVA
    96 Regular Cab 4x4 5spd
    If you broke a ratchet on these things, your ratchet was shit and be glad you broke it on this rather than somewhere else that wouldve cause your hand or knuckles to slam into something hard. These retaining bolts are 12mm bolts that shouldnt be too hard to break lose.
  7. Jun 3, 2014 at 10:32 AM
    SlipperyTaco
    SlipperyTaco Slippery when Wet
    Chandler, AZ
    04 Tacoma 4x4 & 2014 4Runner Trail Premium
    FOX 2.5 C/O, CAMBURG UCA, FOX 2.0 REAR, SMP CUSTOM FRONT BUMPER, BAMF LCA SKIDS, SCS RAY 10 MATTE GREY WHEELS, 305/70/16 BFG KO2, ALL PRO STANDARD LEAF PACK, ALL PRO SLIDERS, U-BOLT FLIP KIT, MARLIN CRAWLER REAR BUMPER, TIMBREN REAR BUMPSTOPS, WHEELERS SS BRAKE LINE F/R, D-BADGED, GIBSON CAT BACK, K&N CAI, LINE-X , GREY WIRE MOD, APOLLO 3.0 SHROUDS, D2S XB 5500K HID BULBS, LED HALOS, LED DEMON EYES, TRS LED BULBS, BHLM, IGGY PODS, CALI RAISED PODS, 30" CALI RAISED 4D LIGHT BAR, BESTOP SUPERTOP, TRASHAROO , WET OKOLE SEAT COVERS. 4 RUNNER- 2014 TRAIL PREMIUM W/KDSS KINGS FRONT AND REAR DIRT KING BALL JOINT UCA METAL TECH LONG TRAVEL SPRINGS METAL TECH UPPER/LOWER LINKS SONORAN STEEL KDSS TRACK BAR URD EXHAUST URD Y PIPE URD MAF CALIBRATOR PEDAL COMMANDER PRINSU ROOF RACK RIGID ADAPT LIGHT BAR SCS SR8 17" GUNMETAL 285/70/17 FALKEN WILDPEAKS TRS FOG LIGHTS TRS HID KIT SS OFFROAD SLIMLINE WITH SIDE PROTECTION COASTAL REAR SWINGOUT HEFTY FAB SKIDS
    hit it with some kano kroil the stuff works wonders.
    heh i even clean my guns with it
  8. Jun 3, 2014 at 10:34 AM
    Smoke
    Smoke Well-Known Member
    Eastern Ontario
    2006 SR5
    Heat up the bolt. Its the fastest safest way to remove rusty bolts. The torch is probably the most used tool in my shop.
  9. Jun 3, 2014 at 12:59 PM
    VintageFast
    VintageFast Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    I think Toyota puts red Loctite on a few of those bolts. I had a hell of a time when I removed mine and it only had 10K on the odometer.
  10. Jun 3, 2014 at 1:03 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    Right here if anything is going to break it loose it will be heat. Penetrating oil only works so much. I would advise heating it and trying to pop it open numerous times. Once that bolt is sheared with to much force drilling it is going to suck.
  11. Jun 3, 2014 at 2:56 PM
    Andy.G
    Andy
    Virginia
    You ever try heating it up and shooting ice water instantly?
  12. Jun 3, 2014 at 5:52 PM
    SaltSlasher
    Utah
    I am about to go at it again. The ratchet I used had a crap system for changing direction, so when I pulled with all my strength the ratchet just loosened and it would change directions. It was just some old one I had lying around that I didn't really like.
    I got me a little propane tank with a torch head that I use for my big oven fire place, and for camping. I am hoping the lube on them over night helped clear them out.
    I didn't want to have to replace them, cause I planned on putting in those all-pro trail armor but I was hoping to get them, the bumpers and the sliders all at once, after I get my suspension.
    These are good ideas, if they give me a hard time I will let you all know.
  13. Jun 3, 2014 at 7:23 PM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    Subd - I'll be doing this soon to get to my rack bushings. They broke off on my old truck, and I'd like to avoid that this time. Let us know how it went.
  14. Jun 3, 2014 at 8:25 PM
    SaltSlasher
    Utah
    I looked up a couple DIY's, and used a propane torch, decent sized hammer, gorilla grip socket, 6 point socket, 8 point socket, star shaped socket, WD40, General Lube, General Use Oil, and used different types of ratchets from regular, to screwdriver handle type.
    I got nothing but two stripped bolts now, and a headache. I have never seen a bolt not come out like that, so I am still stuck. I did notice that the middle one is missing because it isn't aligned. I trying to screw one of the other bolts and couldn't get it in, and may this is a reason why I can't get the others off. I looked at the spacers on these also, and it looks like someone took one of those impact wrench guns and smashed them in something fierce.
    So I really don't know what to do now, I have never seen a torch not work, so I don't know what next step is.
  15. Jun 4, 2014 at 12:54 AM
    phoenix ray
    phoenix ray Well-Known Member
    ray
    Phoenix AZ
    00 PreRunner X-cab TRD
    5100's, AAL, AEM/Spectre true CAI , Magnaflow muffler with mandrel-bent exhaust and header, 4.88's, BFG KO2 12.5 x 33 on 15" AmRacing Outlaw II's, 17" electric cooling fan in factory shroud, frame-mounted remote large-size oil filter, adjustable cam sprocket
    When yer done, clean out the thread holes and tap...don't remember the size. Then, clean out the bolts, and run 'em through a die so that life will be easier next time.
  16. Jun 4, 2014 at 3:03 AM
    Andy.G
    Andy
    Virginia
    Sounds like drill time. Start out with small bit and work your way up in drill bit size. Not sure if easy out will work with bolts so seized. If you can drill most of the bolt in diameter, it might. Otherwise will end up tapping. Sorry for your bad luck, but ain't nothing but a thing. At least it's not performance issue.
  17. Jun 4, 2014 at 5:07 AM
    Smoke
    Eastern Ontario
    2006 SR5
    Did you use the propane or oxyAce to heat it? Because propane doesnt get hot enough or distribute the heat well enough I've found.
  18. Jun 4, 2014 at 8:26 PM
    SaltSlasher
    Utah
    I put general use lube and oil on them last night after doing the WD40 and Torch thing. This morning my ratchet wouldn't work.
    I took my friend to get a hood and bumper for his honda, and back at his house we used his tools. He used an impact wrench on them, and his extender snapped and the socket got lodged on the bolt. So I got his grinder and was putting on the attachment, and he took his ratchet and hooked it onto the socket, and started smacking it with a handheld sledge hammer, and bam, it started loosening. So he did the ratchet with impact socket with 6 point, and did the hammer thing again, and it came loose.
    It was clearly a case of "I loosened it for him". Them bolts were covered in lube and oil, and there was literally no rust on them, cause I cleaned them out with the torch. I guess what I learned was, don't be a pussy when it comes to hammering out bolts, and use proper sockets.
    I am shocked the bolts are still intact. My bro gave me a new set of bolts from his stash, cause the heads on mine were shot.
  19. Jun 4, 2014 at 8:27 PM
    SaltSlasher
    Utah
    I used the green propane tanks with the attachment that goes on top.
  20. Jun 4, 2014 at 8:30 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    I hate installing the skid plates.
