stuck spark plug
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacogriz, Aug 10, 2016.
  1. Aug 10, 2016 at 2:03 PM
    tacogriz
    tacogriz [OP] Member
    griz
    arizona
    flat black 97 4wd tacoma 4 cylinder
    hey yall
    was changing out plugs and cables, easy peazy, (with a magnetic socket) (on my 97 toy tacoma..4 cyl 2.7 ltr 4wd,) can not get one of them out. ive been trying to get it out for the last two hours. when looking down the block with flashlight i see the top of the plug has bare metal showing and also seems to be loose...what the hell should i do
  2. Aug 10, 2016 at 2:25 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    True story.....My Wife's 2007 Rav4, I changed the plugs on the 4 cyl after 6 years (only 32K miles) and all went well except for 1 plug that would not come out. It drove me nutz until I stuck a little Maglite down in and saw a little piece of what snaps on to the plug had broken off from the factory and was stopping the plug from coming out. it was just jammed in there. I finally got that piece out (about the size of a half a dime) and could get the plug out. Look at both the plug hole and what snaps on to the plug to see if anything is missing or down in there.
  3. Aug 11, 2016 at 7:57 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Once you do get the plug out, make sure to dab the threads with anti-sieze for this very reason
    CD20H likes this.
  4. Aug 11, 2016 at 8:58 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Aussiek2000 likes this.
  5. Aug 11, 2016 at 9:00 AM
    cruiserguy
    Elijah
    SEKS
    I know NGK says not to use it as well, I imagine ac Delco does and others also. Just haven't looked it up specifically to other plug manufacturers. I can see why you would want to put a dab on there, I stopped doing it after seeing the manufacturers state not to.
  6. Aug 11, 2016 at 12:12 PM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    dielectric grease works good,,if the never seize scares you. Never seize has ultra fine mesh alum dust in the grease complex. Alum is a natural insulator (and self lubricator) so they try to scare you away from that voltage loss. A tiny,tiny pinprick dab down low on the threads if you must. Dielectric is a voltage isolator,,so it concentrates it on that spot of the plug. Good for ALOT of heat and upwards of 15K volts. what I have switched over to and the plugs screw right out.
  7. Aug 11, 2016 at 1:08 PM
    cruiserguy
    Elijah
    SEKS
    Makes sense, thanks for the heads up.
  8. Aug 11, 2016 at 7:05 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Hmm thanks, I will use this next time.
  9. Aug 12, 2016 at 4:28 PM
    CR, WA
    stock
    Cool. Also changes the heat range of your plugs to a point, if you use a big loaded swipe of NS on the threads. Less is better. Our team runs a 780" Gene Fulton bbc and we run NGK exclusively,,because they can take it, and that we are pounding them with high amps and 16 volts for the first 30° of low rpm timing. Those plugs get a NS swipe every other set or two (alum head). Even flattened washer plugs can stick horribly if you don't break them free immediately in the pits while still hot (key).
  10. Aug 12, 2016 at 5:53 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    I use anti-seize on my plugs. A $5 plug is easier to replace than to repair/replace a $400 head(not including labor) with stripped plug hole threads. Do the right thing, put anti-seize on the plug threads. I don't care what the plug makers say. I will be the one paying for broke shit.
    mistafier likes this.
  11. Aug 12, 2016 at 5:54 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Be careful. Last time I saw a plug get stuck in one of these, the guy snapped it off and had to pull the head and send it to machine shop
  12. Aug 12, 2016 at 8:18 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Will the plug run hotter with anti-sieze?
