Stuck Tacoma - Front Lockers?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mgord, Mar 1, 2009.
  1. Mar 1, 2009 at 10:32 AM
    mgord
    mgord [OP] Well-Known Member
    Harrisburg, PA
    07 TRD
    K&N, Leaf Springs, Home Built Camper
    Looking for any advice on Front Lockers. I'm new to the locker game but very handy with a wrench. Can anyone recommend front lockers that won't break the bank and the warranty as well? ARB? LSD? I would only use these part time and am looking more for a limited slip option vs a full-time locker.
    I got stuck this weekend on a very icy road (thanks to snowmobilers) trying to get to my back packing destination. I put the tires in the ditch on purpose because the other side was not an option. I was able to travel down the side a few hundred feet in 4 low with the rear locked. If I had front lockers I think I could have made it all the way down. A tow truck with chains on all fours came and fished my but out by backing up all the way and giving me a tug ($200). I carry a winch and tow ropes but the trees were too far away.
    Please be specific and where to buy.
    And yes that is a home built camper which I slept in all night with my son. We got stuck a 9pm and pulled out at 10am.
    Thanks.
  2. Mar 1, 2009 at 10:39 AM
    Bearskill
    Bearskill Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    How much does that camper weigh? Im trying to resist, but.................
    WTF? Insted of a locker, take that 300 lbs of lumber off your back end! Damn!
    Im sorry, to each his own. If you like it it's your truck. Wait Im losing it again, aaahhh
    WTF is on the back of your truck?!?! It doesn't even fit!
    dingel5 likes this.
  3. Mar 1, 2009 at 10:46 AM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    So you'd do different with your Bear Skills? (hee hee)
  4. Mar 1, 2009 at 11:02 AM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    im not sure if you locked the front, if it wouldnt void any warrenty. You may want to consult with toyota for that. Also, where in harrisburg are ya? I usually go up there for the All Truck Nat's in August..Some beautiful country up there
  5. Mar 1, 2009 at 11:08 AM
    sonjay
    sonjay Well-Known Member
    I would say pretty much the only option for the front would be an ARB air locker, I don't even know of any other companies that make a front locker for our trucks? Maybe Chris4x4 might know of some others. The nice thing about the ARB is its selectable, like your rear e-locker, but uses air instead. Of course they are not cheap, $800-$1000, plus install and setup, and you will need an air compressor to engage them.
  6. Mar 1, 2009 at 11:25 AM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    You might want to look into a set of chains, maybe wouldn't have slid off in the first place if iron were on at least the back since these new Tacoma's don't have much room for front chains.
    If you had a pair with you by the looks of the pic you could have gotten a tire chain on that left rear, since that diff is locked, it a good chance you would have gotten out.
    Tow trucks suck
  7. Mar 1, 2009 at 11:29 AM
    silver07taco
    silver07taco Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
    Im not sure if a front locker whould have helper out out any in that spot but im not 100%, As far as lockers your goin to want a locker you can turn on when you need it and off when you dont, ARB is the best one I know of But there not cheap and your goin to have to have a on board air to run it.
  8. Mar 1, 2009 at 11:30 AM
    mgord
    Harrisburg, PA
    07 TRD
    I looked at the ARB setup. Expensive!
    I will have a pair of chains in the top of the camper next time along with my winch.
  9. Mar 1, 2009 at 11:33 AM
    silver07taco
    COIL
    Maryland
    You have a winch might want to look into a line extension or one of them anchors.
    http://www.pullpal.com/quotes.html
  10. Mar 1, 2009 at 12:50 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Chains would have solved that problem... the only problem with chains is that you need to have them on before you get stuck! I've seen snow/ice make even the most serious rigs useless without chains.
    Bummer about the winch. We have the same problem here, not many trees in the desert. You might want to invest in an extra 100'+ of nylon cable to keep onboard for the next time that happens. Nylon cable will always be cheaper than a locker, and pay for itself in towtruck calls.
  11. Mar 1, 2009 at 12:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I was thinking the same. An ARB locker.
  12. Mar 1, 2009 at 1:36 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    An ARB is all I know of for the front end of these trucks. They're quite spendy though. curious, how much cable was on your winch? A synthetic extension rope would be a good investment in this case. Otherwise, definitely get some chains.
  13. Mar 1, 2009 at 1:56 PM
    nvdeserted
    Reno, NV
  14. Mar 1, 2009 at 2:10 PM
    RelentlessFab
    Eric
  15. Mar 1, 2009 at 2:45 PM
    mgord
    Harrisburg, PA
    07 TRD
    Thanks for the info on the emergency tire chains.
  16. Mar 1, 2009 at 3:01 PM
    nvdeserted
    Reno, NV
    I've never used them but I can think of about 15 times I wish I had had them. Definitely gonna order a pair.
    Also, that link is to the E-chains for 265/70-16 size tire/wheel. Make sure to go back and select the right size tire/wheel before ordering.
  17. Mar 1, 2009 at 3:04 PM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    Damn mgord....you scared me there a bit......looked like the darn Unabomber cabin escaped......crikey! Do you tow a small outhouse behind ya?
    dingel5 likes this.
  18. Mar 1, 2009 at 3:18 PM
    mgord
    Harrisburg, PA
    07 TRD
  19. Mar 1, 2009 at 3:25 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
  20. Mar 1, 2009 at 3:28 PM
    mgord
    Harrisburg, PA
    07 TRD
    Yes to the space heater and insulated. I've been out in 10 degree weather sleeping like a baby.
